Death Wobble Braking from 50+ - JeepForum.com
post #1 of 13 Old 02-20-2011, 12:13 AM Thread Starter
samhay
Been getting some wobble while braking from 50+ mph to about 25 or 30 mph for a while now but nothing major. Last night driving home, shifted to neutral going 60 mph and got horrible death wobble like my tie rod was about to fall off. Went hard on the brakes and it went away at about 15-20 mph. Suspension is just about on its last leg and not sure if any of the linkages have had any work done. Anyone have any suggestions?
97 TJ 4.0L, Ford 8.8 LS, 3in, 32s, Headers plus Full Exhaust
73 CJ5 Renegade, 304 V8, D44 Rear, D30 Front, 35s
samhay is offline
post #2 of 13 Old 02-20-2011, 01:12 AM
cadencedad
cadencedad's Avatar
mine was a mixture of allignment and the steering stabilizer. The reason i say mixture i replaced and alligned the same time so not sure if the steering stabilizer was a big part. It was leaking so i changed it.. I know allignment plays a huge part. List of the following checks....bent rim,allignment, bad or bubble in the tire, steering stabilizer. ball joints tier rod ends.. Hope i helped
cadencedad is offline
post #3 of 13 Old 02-20-2011, 01:43 AM
Heath
2014 JK Wrangler
STEERING STABILIZERS NEVER EVER NEVER EVER NEVER FUX DEATH WOBBLE. NEVER.
They will MASK it SOMETIMES, but NEVER fix it.
You probably have some morn front suspension parts. Check all the control arm bushings, and track bar ends, ball joints, and all steering rod ends. Make sure the track bar is tight and the bracket hole isn't ovaled.
Heath is offline
post #4 of 13 Old 02-20-2011, 02:28 AM
KKiowaTJ
Might look into having your front rotors turned or replaced. They might have build up on them which will cause wobble while braking. My XJ had that problem and new pads and rotors cured it. Good luck
MOPAR!
KKiowaTJ is offline
post #5 of 13 Old 02-20-2011, 02:32 AM
cadencedad
cadencedad's Avatar
i have herd of mud bulidup causing wheel to wobble too
post #6 of 13 Old 02-20-2011, 07:09 AM
04Wrangler2000
Is it doing it when you begin to brake?
04Wrangler2000 is offline
post #7 of 13 Old 02-20-2011, 07:11 AM
04Wrangler2000
Oh I just read that it is when braking. You probably need to get new brakes/rotors.. Had the same issue. Brakes fixed it.
post #8 of 13 Old 02-20-2011, 08:39 PM Thread Starter
samhay
Thanks Everyone! Ill start wrenching when i return from snowboarding in CO and let you know
samhay is offline
post #9 of 13 Old 02-20-2011, 09:32 PM
WranglerAngel05
Yeah, if it's when your braking...I used to get horrible shaking like that because of rotor issues. I was never hard on my brakes, I just assumed it was a common problem. It happened within the first 3 years of ownership, but since new rotors, it's been fine ever since.
Now if it's doing that in neutral at 60 mph, that's weird. I had been getting horrible "death wobble" a couple months back - started at between 55-65 mph. It was so bad at times, I thought I would lose it if I didn't slow it down. Thought it was gonna be my stabilizer bar too, but it was my tires! They were worn so inconsistent/ rutted and, therefore, so unbalanced that at a certain speed, it started shaking. They still had decent tread, its just they had worn crooked. New tires did the trick. Still may change the stabilizer bar to be safe.
~ ~ Barefoot. The REAL way to drive a Jeep. ~ ~
Sweet Tea, men in Wrangler jeans, Trans Am's, sitting in the sand, Jeeps, mud, diesel trucks, hot summer days, bluegrass music, picnics, flip flops, and bubble gum...
Who says life has to be any more complicated than this?
"We roll the dice we, play like fools
We plead with time to change the rules
It's like a hurricane is coming our way
We've all been warned but we still chose to stay" ~ Needtobreathe
WranglerAngel05 is offline
post #10 of 13 Old 04-26-2012, 10:30 AM
Heysus
Mine STARTED only on braking, this morning was the first time it happened by itself while cruising at 35 - 40 MPH.
I didn't touch the brakes but it started doing the worst rattling / wobbleling I've felt yet. Any suggestions?
many thanks JeepForum!
Heysus is offline
post #11 of 13 Old 04-26-2012, 10:56 AM
Heath
2014 JK Wrangler
Check your balljoints really well, along with the other usual suspects.
2013 JKU Rubicon
Heath is offline
post #12 of 13 Old 10-05-2013, 11:55 PM
Acc0919mc
i have a similar issue, but mine doesnt shake unless i touch the brakes. i would hit the brakes going about 55 and it would shake like hell! and guess what? if i let off the pedal it doesnt stop! it just keeps going like its trying to kill me or something.
Acc0919mc is offline
post #13 of 13 Old 10-06-2013, 06:24 PM
KKiowaTJ
That's the same issue I had two years ago IIRC or how old this thread is. The same thing still fixed it 100% to the day. A new set of pad's and rotor's will solve it. The only other thing would be a bad bushing or slop in the track bar from letting it go and not fixing it asap.
MOPAR!
KKiowaTJ is offline
death wobble , tj
Solution to steering wobble and death wobble...need help Sparty TJ Wrangler Technical Forum 5 10-01-2010 07:25 AM
Death Wobble, When Braking at Speeds over 50MPH tdog522 TJ Wrangler Technical Forum 2 03-25-2008 04:13 PM
Death Wobble during braking? chaz7979 TJ Wrangler Technical Forum 19 08-10-2007 06:42 AM
Steering Wheel Wobble. Not Death Wobble. bigbarr TJ Wrangler Technical Forum 1 05-29-2007 12:29 PM
crazy (death?) wobble while braking badoosh27 TJ Wrangler Technical Forum 7 04-19-2007 03:00 PM
