Quantcast death wobble Alignment pitman arms -HELP! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > death wobble Alignment pitman arms -HELP!
Spartan Lockers FREE SHIPPING Excellent PricesDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-Mojave Cut & Fold Rear Bumper – Jeep Cherokee XJ
Old 11-05-2008, 06:47 PM   #1
Crunchakah
lemme list what i have on the jeep first:
4" procomp lift
33x12.5x15 BFG MT KM2
I had a dropped pitman arm and it felt like the front driver wheel was hopping. and reading on the forums, i see that a dropped pitman arm is not needed with a 4" lift, and it causes bump steer. I had the jeep aligned previous of putting the stock pitman arm back on. now that i have the stock pitman arm, not only did the mofo not straighten the steering wheel.. it seems to pull to the left now and i got a death wobble.. couldnt stop it until i brought the jeep down to 10mph. WTF
Does the pitman arm screw with the alignmet/steering when changing from dropped to stock?
the bump steer seems better... now just the DW and pulling to the left..
i also read somewhere to drill another hole 1/2" closer in where the trackbar mounts on the axle. IS this right? its currently in the new hole. Should i move it back?
the jeep is great..... but this steering is a nightmare!
HELP!
2003 Wrangler X 4.0L 5spd
4" Pro-Comp/ 33x12.5x15 BFG M/T / Rock Crawler
4.56 gears D30(Aussie)/D35
97series 15x10/ ARB Snorkel / Flowmaster 40 Series
Warn RC Front/Rear Bumper w/tire carrier /grille guard
XRC8 Winch/ KC Daylighters /IPF h4 lights
Crunchakah is offline   Reply With Quote
Old 11-05-2008, 06:59 PM   #2
cheapjeep06
cheapjeep06's Avatar
Changing from drop to stock pitman arm without an alignment would cause toe in, and your steering wheel will be off center. Get it lined up (I did my own with tape measure and a friend). This should help.
2006 Golden Eagle; 4.0L, 6-speed; D30 front, D44 rear, 3.73; RC 2.5" lift w/1" spacer in front; 1.25" BL; 1" bmml; 33x10.50 BFG KM2's; 1 1/2" RC wheel spacers; Full Boar muffler; RC 2.2 steering stabilizer; AEM filter on stock tube; HF 9000lb. winch; Rough Country adj front track Bar; XRC Rockers
cheapjeep06 is online now   Reply With Quote
Old 11-05-2008, 07:01 PM   #3
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
First, you did the right thing by reinstalling the OE Pitman arm. To straigthen the steering wheel, you just need to turn the adjustment link on the drag link (see below) until it's straight again.
If your front axle is a little to the side, yes relocating the passenger-side mounting bolt to a new hole drilled to the driver's side works well to help get it back to the center again. I ran mine like that for several years before I could afford an adjustable length trackbar.
Your toe-in is likely off from changing the Pitman arm which can cause it to pull to the side. Adjust it so the front edge of the front tires are 1/16" to 1/8" closer together than they are in the rear per the instructions at http://www.4x4xplor.com/alignment.html. Just a little care will produce a toe-in adjustment every bit as accurate as an alignment shop can give. The bottom photos show a more accurate means of making that 1/16" to 1/8" measurement than is shown on that website. The aluminum tubing in the below photo is marked so it is the same as the tire size, so you would have it marked so the marks are 31" apart, centered on either side of the wheel.
Finally, for your Death Wobble... make sure your passenger-side trackbar bolt is TIGHT (45 ft-lbs.) and that your tires are all perfectly balanced. Those two areas are frequent sources of Death Wobble.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 11-05-2008, 07:53 PM   #4
Crunchakah
thanks Jerry once again!
Glock Forum
