Death wobble - JeepForum.com
post #1 of 25 Old 10-28-2008, 04:32 PM Thread Starter
Brad99tj
Death wobble
Hello everyone ive been battling death wobble for a while and i feel like ive tried everything. Ive replaced ball joints, wheel bearings, steering stabalizer, replaced all tie rod ends, rotors turned, wheels rotated and balanced, everything. Well i guess the only thing left is tires and a tie rod, Well my tires arent to bad so im gonna get a new tie rod. Any suggestions on which one to get? i have 4 inches of lift and 33-12.50 tires on a 99 jeep wrangler. Any suggestions would be helpfull, thanks
Brad99tj is offline
post #2 of 25 Old 10-28-2008, 04:34 PM
willbacker45
alignment? lol you didnt say that if you didnt then try it
willbacker45 is offline
post #3 of 25 Old 10-28-2008, 04:35 PM
willbacker45
alignment? lol you didnt say that...i hope you got one otherwise you possibly wasted money and time
post #4 of 25 Old 10-28-2008, 04:39 PM Thread Starter
Brad99tj
Sorry forgot that one yeah i did that
Brad99tj is offline
post #5 of 25 Old 10-28-2008, 05:15 PM
rulman
went thru same thing, put in 1" MML and RE adjustable track bar... wobble all gone
rulman is offline
post #6 of 25 Old 10-28-2008, 05:28 PM
djmiani
what does a MML do to help stop the wobble?
djmiani is offline
post #7 of 25 Old 10-28-2008, 05:30 PM Thread Starter
Brad99tj
What does the motor mount lift do to help if you dont mind me asking?
Brad99tj is offline
post #8 of 25 Old 10-28-2008, 05:37 PM
famous1688
1989 XJ Cherokee
i had the same thing, it ended up being the tires needed to be balanced... and i took it to a shop... the "balanced them" and it worked ok.... i got to go like 20 mph faster than i could before... so i took it to a diff shop "les schwab" and watched them balance them... its amazing what good equiptment can do.... i'd suggest goin to a shop with a laser balancer... there way more precise... and btw... bad allignment cant give you a wobble... ever....
4.5in RE superflex lift, 32's, custom bumpers under construction...
famous1688 is offline
post #9 of 25 Old 10-28-2008, 05:44 PM
JESSETHELJ
JESSETHELJ's Avatar
A bad aligment can to give you a horrable wobble try doing a alighment when its on jack stands and then going 45 mph. Got some bad info. took it home and re did it on some level pavement and it hasent wobbled sence.
Try this I think it might help.http://www.4x4xplor.com/alignment.html
2004 LJ*RIP Love * Ex-Wife Stole you and Sold you *Current 1999 XJ Heep
JESSETHELJ is offline
post #10 of 25 Old 10-28-2008, 05:46 PM
YJSXJ
1993 XJ Cherokee
TRAC bar worked for me
looking for 33x12.5x18 tires.
Bruiser -- 93 XJ Sport. 9.5" lift on 35"" Claws, Locked front & Rear, and some other crap. Rolled it
Cruiser -- 1998 XJ Classic. 3" RC lift. 32" Kuhmo Ventures. Sold it
1999 WJ Limited V8. 4" Mix-n-Match Lift. Nothing special.
YJSXJ is offline
post #11 of 25 Old 10-28-2008, 05:47 PM
famous1688
1989 XJ Cherokee
no.... it cant... im a.s.e. certified and alignment is my specialty.... trust me...
post #12 of 25 Old 10-28-2008, 05:50 PM
JESSETHELJ
JESSETHELJ's Avatar
So Toe out can not cause a caster effect?
post #13 of 25 Old 10-28-2008, 05:52 PM
famous1688
1989 XJ Cherokee
it can... but it wont cause it to wobble... it will vibrate slightly but no death wobbles...
post #14 of 25 Old 10-28-2008, 05:54 PM
JESSETHELJ
JESSETHELJ's Avatar
Well alright was just commenting on my experience. Having the Jeep almost roll was no way compared to doing 45 mph and getting tossed around like a mexian jumping bean. I redid the alighment and it fixed it.
Hey If your ASE look at my post about this issue im having with my IAC
Sorry not to hijack thread
post #15 of 25 Old 10-28-2008, 05:57 PM Thread Starter
Brad99tj
any suggestions on which track bar to get? I looked at the re one but there was a review on it that said it was good up to four inches of lift, if i need to get somthing better like the whole assembly i will. Its either get this fixed or go shopping and i really dont want to get rid of my jeep
Brad99tj is offline
Solution to steering wobble and death wobble...need help Sparty TJ Wrangler Technical Forum 5 10-01-2010 07:25 AM
DEATH to the death wobble....wooohooo jeeperscreep04 TJ Wrangler Technical Forum 6 09-19-2009 01:31 PM
Steering Wheel Wobble. Not Death Wobble. bigbarr TJ Wrangler Technical Forum 1 05-29-2007 12:29 PM
is it death wobble or death steer frank_frank139 TJ Wrangler Technical Forum 4 03-06-2007 11:56 AM
wobble problem (not death wobble) mkalcevic TJ Wrangler Technical Forum 6 07-27-2006 03:56 PM
