death wobble - JeepForum.com
post #1 of 15 Old 06-02-2013, 09:38 AM Thread Starter
jeeple
death wobble
Seems I'm not the only one with this problem!!! Why isn't Chrysler Corp involved in this problem?
jeeple is offline
post #2 of 15 Old 06-02-2013, 09:40 AM
rchase559
You have worn out suspension components. Fix them.
rchase559 is offline
post #3 of 15 Old 06-02-2013, 09:43 AM
biffgnar
biffgnar's Avatar
Educate yourself about death wobble. All solid axle vehicles are subject to developing it as parts wear. Its physics. Not something that Chrysler or any other manufacturer can change as long as solid axle vehicles are built. Take care of your vehicle and all will be good.
Romney in 2020!
biffgnar is offline
post #4 of 15 Old 06-02-2013, 10:43 AM
tyvanwie
Not sure if serious...
Sent from my iForum using JeepPhone
tyvanwie is offline
post #5 of 15 Old 06-02-2013, 12:02 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
If he is, then he's one of the people at Maxim magazine that voted Miley Cyrus as the hottest woman in the world!She looks more like Justin Bieber's more manly twin brother.
TheBoogieman is offline
post #6 of 15 Old 06-02-2013, 12:05 PM
tyvanwie
tyvanwie is offline
post #7 of 15 Old 06-02-2013, 12:17 PM
TheBoogieman
Disturbed
I like the new avatar.
post #8 of 15 Old 06-02-2013, 12:23 PM
tyvanwie
Thanks
tyvanwie is offline
post #9 of 15 Old 06-02-2013, 04:09 PM
Wrangler328
I think my 02 Wrangler has this "death wobble". At 60mph it shakes. Not so much the steering wheel but it mostly feels like the wheels are shaking. I'm trying to research and see if I have death wobble or not. It seems the beginning steps are rotating the tires/ getting new tires or an alignment. I recently got the Jeep and the owner said the ties have 10k left on them. Are there any signs or anything I should look for underneath in order to determine if the problem is more serious?
Thanks!
Wrangler328 is offline
post #10 of 15 Old 06-02-2013, 04:14 PM
tyvanwie
Thanks!
Worn out parts.
tyvanwie is offline
post #11 of 15 Old 06-02-2013, 04:57 PM
MotoSoul
Just for the record if you only think you have death wobble then you don't have it. When you get death wobble the only way to stop from losing control of the vehicle is to apply the brakes to low way down.
I like the arms, they are a good solution, but they really aren't worth the effort for the average person and you already see the BS that goes on over bushings VS JJ's, the crap that would go on over J arms would be epic.
MotoSoul is offline
post #12 of 15 Old 06-02-2013, 07:10 PM
Wrangler328
Ok. And, awesome I hope I do not have it! Well, at 60 when it started to "wobble" so I just let off the gas and once back in the 50s it stopped.. so having that info you still think its probably not death wobble? If so, what is it? I have not tried to push it past 60 b/c I was scared enough when it started wobbling and it felt unsafe.
Thanks for the help!
post #13 of 15 Old 06-02-2013, 07:22 PM
Gary2
Any vehicle with badly worn front end components are unsafe. Be glad a TJ will tell you that it has not been properly maintained and needs to be fixed.
Gary2 is offline
post #14 of 15 Old 06-02-2013, 07:31 PM
tommyduncan
My 05' had death wobble. I tested/checked/swapped many different components and minimized it but it would still do it occasionally.
Even though my tires were new and balanced several times changing them made it go away.
I know it didn't fix anything. The problem is still there. It just masked it. About to completely redo a high pinion with all new parts. Hopefully that will take care of it.
My buddys Samurai did it and I had a CJ7 that did it too...
tommyduncan is offline
post #15 of 15 Old 06-02-2013, 10:33 PM
guido79
Re: Death Wobble
I have a 2002 TJ with oversized tires and a 3" lift kit with about 83K miles on it. Today, I experienced my first Death Wobble. Scared the SH** out of me at about 60 mph down the freeway. After researching this a bit today, here's some helpful links if you want to read up on causes and how to fix:
Jeep "death wobble" leaves drivers shaken
Death Wobble: How To Fix Your Own Case of Dreaded Death Wobble
If you're a do-it-yourselfer, Kevin's Offroad makes a "Death Wobble Package for TJ Wranglers" for $367.
Hope this helps.
Guido79
guido79 is offline
