Death Wobble - JeepForum.com
post #1 of 4 Old 05-29-2013, 07:30 AM Thread Starter
Jeeepgirl
Death Wobble
I have owned jeeps for years but have never been really technical or knew how they worked. I need suggestions and help from those of you who know what you are talking about so please excuse the ignorance. I own a 2011 Jeep Wrangler Unlimited Sport. In December I was on my way home from Charlotte late night and hit a bear with the front passenger bumper. The entire front end started shaking violently and I thought that I had busted tires or something. When I calmed down and decided there was no risk for bear attack I got out to check out the jeep and there looked to be no damage to the jeep. At least twice on the way home I had death wobble (but didn't know what it was at the time.) I turned the jeep in on insurance and they sent me to my local shop (who were apparently as clueless as I was) and the shop then stated there was nothing wrong with the jeep. They did an alignment and sent me on my way.
All was well for a few months then I started having death wobble again. I did some research online and noticed that the culprit if often loose track bar. I had my husband tighten the track bar (it was slightly loose). It worked for a while but then continued to have the problem. I took it to jeep dealer this time who told me I had two busted front shocks and they wanted $500 to replace the shocks. They again tightened the track bar. I decided since I had always wanted to have a small lift on my jeep I would instead have a different local guy install Rough country 3.25" suspension lift which included shocks. One week after installation still having the same problem. Any suggestions? I am a total novice but I'm slowly learning.
Jeeepgirl is offline
post #2 of 4 Old 05-29-2013, 07:36 AM
tyvanwie
Check for worn out parts. Also search around on here and you'll find it. By the way, you own a "JK" and this is the "TJ" section, but I'm sure a mod will move it
Sent from my iForum using JeepPhone
tyvanwie is offline
post #3 of 4 Old 05-29-2013, 07:55 AM Thread Starter
Jeeepgirl
Like I said I'm a novice
post #4 of 4 Old 06-02-2013, 10:47 PM
guido79
Re: Death Wobble
After researching this a bit today, here's some helpful links if you want to read up on causes and how to fix:
Jeep "death wobble" leaves drivers shaken
Death Wobble: How To Fix Your Own Case of Dreaded Death Wobble
If you're a do-it-yourselfer, Kevin's Offroad makes a "Death Wobble Package for TJ Wranglers" for $367.
Hope this helps.
Guido79
guido79 is offline
death wobble , death wobble diagnosis , Rough Country 3.25"
