Death Wobble! - JeepForum.com
post #1 of 12 Old 01-21-2012, 10:04 AM Thread Starter
leojaz81
Death Wobble!
I need help! I just installed a 4" Rough Country N2.0 suspension lift. When I drove it home...after hitting the smallest bumps...my Jeep went into all out death wobbles until I slowed down to at least 25 mph. I did notice that the tires are toed in pretty bad now after the install and plan on having an alignment soon. Are there any other fixes or concerns I should probably look in to?
Z-Pow
leojaz81 is offline
post #2 of 12 Old 01-21-2012, 10:08 AM
Jeepinty
Check the normal stuff, loose/worn out front end parts etc. Get the alignment checked like you said.
Jeepinty is offline
post #3 of 12 Old 01-21-2012, 10:11 AM
robncar
robncar's Avatar
How would you describe "death wobble"?
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #4 of 12 Old 01-21-2012, 12:21 PM
TJ-chopper
Did you use a drop pitman arm if so take it back OFF and install the factory arm
1997 TJ 4.0, Automatic with a 4" Zone lift and BDS adjustable control arms, AA transfercase shifter relocator bracket, Real Flat fender, custom front bumper with Stinger and 8000 lb winch. custom rear bumper with swingout tire carrier, Viking soft top, 4.10 gears, SYE and Tatton DS , Goodyear Dura Trac 33x12.50-15 and still working on it.
TJ-chopper is offline
post #5 of 12 Old 01-21-2012, 12:36 PM
RaggedOleMan
If you have genuine DW, here's a link to an excellent write-up about diagnosing & resolving it. Lengthy, and good; Death Wobble
RaggedOleMan is offline
post #6 of 12 Old 01-21-2012, 01:42 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
You can't do a 4" lift and not align it immediately and not have DW.The toe will be off by an inch.I had to drive mine 25 mph on the interstate after my lift and tire install.I drove it to the tire place with stock tires and it was bad when I hit a bump.After the tire install I couldn't drive it over 25 mph without DW on the highway.
TheBoogieman is offline
post #7 of 12 Old 01-21-2012, 03:11 PM
ytowntj
You can provided you have all good components of adequate size in the front end. The toe being off can induce death wobble by adding more forces that need to be controlled, but the loose/worn out or undersized parts are the true cause. If you set the toe the wobble will most likely go away for now but there is a TRE, or trackbar bolt or bushing etc that is on its way out.
Parting my TJ:
My build - Odd approach to 33's
ytowntj is offline
post #8 of 12 Old 01-21-2012, 05:49 PM
Jeepers8099
RaggedOleMan, thanks for that link. I plan on using that information to attempt to troubleshoot my death wobble. In the meantime, I was wondering if anyone had any input on my situation.
I put a 3.25" Rough Country lift on my TJ, and I had death wobble right away. I took it to a shop for an alignment and they also replaced the camber bolts. The death wobble was still there. I dropped it off again and the shop suggested replacing the stock track bar with an adjustable one. They also mentioned that the top of the track bar appeared to have some play. I held off on this repair because I wanted to do some more research. The interesting thing is that the temperature dropped right after that and the death wobble went away. The temperature went back up to the upper 50s and death wobble came back. Again, the temperature dropped to the 30s and no death wobble. I mentioned this to the shop and they were stumped. They suggested increasing tire pressure to simulate stiffer sidewalls in cold weather. This actually made the death wobble occur more frequently. Anyone have an idea of what I'm dealing with?
FYI: I'm sure it is death wobble...I'm actually surprised the doors don't pop open it shakes so bad.
Jeepers8099 is offline
post #9 of 12 Old 01-21-2012, 05:53 PM
jeepinjeffrey
Like was said get an alignment! That was my problem after my lift and tires. if that doesnt fix it them check your trackbar and bushings.
2003 Wrangler Sport
4.5 Rubicon Express Lift|33" BFG KM2s|Ion Alloy 174|And never ending wish list!
jeepinjeffrey is offline
post #10 of 12 Old 01-21-2012, 05:59 PM
RaggedOleMan
DW occurs when the front end can no longer control the forces visited up on it. That could mean;
- track-bar bushings, axle or frame end.
- Tie rod/either end/side
- Drag Link/either end at TR or Pitman arm
- Control Arm bushings, upper or lower frame end
- Control Arm//upper bushing on the axle...
One has to go through the arduous task of diagnosing. If anyone posts up a quick "cure" it would likely be little more than a lucky coincidence if it indeed solved it. I fought this, and chased it down for months. MrBlaine offered lots of counsel & advice and ultimately I was able to track it down. In my case it was NOT just one component. Furthermore, after I replaced the stock tie/rod & drag link with Currie, the DW came back and destroyed my Currie drag link. It can & will desroy new parts darn near as quickly as you can put them on.
I would start with the track-bar. Don't just look at the damn thing and decide it looks okay. Either do a dry steering test or take the thing off and test each bushing individually. Same goes for control arm bushings. Looking at the thing likely won't tell you *****. Take them off, look/inspect them closely. It isn't rocket science, but it is a monumental pain in the *** for many of us. It was for me anyway. I have no short cut for you. It takes what it takes...
post #11 of 12 Old 08-08-2013, 07:41 PM
IncaGirl
I know this was posted forever ago but,
I just put a 4" rough country NC on my 03 Tj and I have death wobble even after I had the alignment done.
I had then check everything the last time it happened (today) and the only thing they could notice was my Track bar is worn and he says I should replace it, but my question is when I did the lift I had to make a new hole for my track bar to bolt into.
Has anyone else had to do that or?????
Help please!!
IncaGirl is offline
post #12 of 12 Old 08-08-2013, 08:07 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Help please!!
Some reading for you:http://www.jeepforum.com/forum/f9/br...racket-905624/...
Knuckelhead is offline
alignment , death wobble , suspension lift
Forget death wobble, this is was a death vibrate to hell flabombero TJ Wrangler Technical Forum 6 05-18-2011 04:07 PM
Solution to steering wobble and death wobble...need help Sparty TJ Wrangler Technical Forum 5 10-01-2010 07:25 AM
DEATH to the death wobble....wooohooo jeeperscreep04 TJ Wrangler Technical Forum 6 09-19-2009 01:31 PM
Steering Wheel Wobble. Not Death Wobble. bigbarr TJ Wrangler Technical Forum 1 05-29-2007 12:29 PM
is it death wobble or death steer frank_frank139 TJ Wrangler Technical Forum 4 03-06-2007 11:56 AM
