Death Wobble?? - JeepForum.com
post #1 of 12 Old 11-30-2011, 11:38 AM Thread Starter
Jo1175
Death Wobble??
It happens at 60mph... Whats the most common cause? So many posts...hard to know what to do first...I don't see anything worn....New Tires and alignment needed? Steering damper? Thanks
Jo1175 is offline
post #2 of 12 Old 11-30-2011, 11:43 AM
Okiejeeptj
I have the same problem at around 35mph, and when I hit big bumps in the road. I am still looking for a way to fix it, but I did tighten up my suspension and it helped a little bit.
Okiejeeptj is offline
post #3 of 12 Old 11-30-2011, 11:45 AM
JeepManager
Get a second person to be in the driver's seat and move the steering wheel back and forth rapidly. You inspect the tie rod ends, and the joint where the tie rod meets the drag link. With the rapid back and forth you'll easily see if there's any play in those steering components.
If they look good, check ball joints visually with the wheels off. Sometimes there isn't enough play to notice and it holds together fine at lower speed, but when you get up there all hell breaks loose (this was the case on mine just the other day when I had the same problem as you).
After those two things you can measure the width between the tires at both the front most point and the rear most point to ensure your allignment is on. The distance between the tires at the front most point should be 1/8" less then at the rear most point.
Check air pressures in tires. Did you loose a bead recently and get dirt in there? Don't know how hard you wheel and if that may have happened at some point.
JeepManager is offline
post #4 of 12 Old 11-30-2011, 11:55 AM
flying_bosun
If I'm not mistaken, 60mph occurrence is commonly a wheel balance issue. Whatever it is, it's NOT the steering stabilizer.
Follow the advice above and/or read more after having balance done an checking wheels for trueness. (they can be both balanced and out of round or un-true at the same time, which can make dx-ing DW difficult sometimes.)
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline
post #5 of 12 Old 11-30-2011, 12:02 PM
Okiejeeptj
I don't wheel very much and my LJ only has 60k, I'll look at my tie rods and ball joints. My alighnment is on, my tires are balanced and inflated properly.
post #6 of 12 Old 11-30-2011, 12:14 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Originally Posted by JeepManager View Post
Get a second person to be in the driver's seat and move the steering wheel back and forth rapidly. You inspect the tie rod ends, and the joint where the tie rod meets the drag link. With the rapid back and forth you'll easily see if there's any play in those steering components...
Good advice.
Also check the track bar while doing this. Watch both ends for any movement.
Wheelin98TJ is online now
post #7 of 12 Old 11-30-2011, 12:19 PM
adixon94
i had it when i hit a bump at 45 and i rotated my tires no i just have a shake at 50 so i think it has to be tire balance on mine and im guessing you have to same issue.
adixon94 is offline
post #8 of 12 Old 11-30-2011, 12:19 PM
JeepManager
Originally Posted by Wheelin98TJ View Post
Good advice.
post #9 of 12 Old 12-01-2011, 09:08 AM Thread Starter
Jo1175
Tie rod and drag link are new....I am goin to start with checking the alignment myself....change the shock...then get new tires... Does anyone have a nice set of rims and tires for sale?? 30's
Jo1175 is offline
post #10 of 12 Old 12-01-2011, 09:11 AM
Imped
Imped's Avatar
Never heard of it.
OlllllllO
IndyORV
Imped is offline
post #11 of 12 Old 12-01-2011, 09:33 AM
Vinrod
Had the same problem years back, verify that your steering linkages are tight, swap out the steering stabilizer (highly recommend using a pitman arm puller to remove the old one) get a wheel alignment and the tires balanced. Ultimately changing the SS did the trick. It only happened to me between 55 and 60mph.
Vinrod is offline
post #12 of 12 Old 12-01-2011, 10:35 AM
JeepManager
With him being on 30's, having no steering stabiliser would only give a slight vibration... if any.
If it's an actual "Death Wobble" then it may be more serious then that.... Although you're right it would help a bit if his is blown.
I have 33's, inverted T steering, and no stabiliser. I get almost no vibration even at highway speed.
Forget death wobble, this is was a death vibrate to hell flabombero TJ Wrangler Technical Forum 6 05-18-2011 05:07 PM
Solution to steering wobble and death wobble...need help Sparty TJ Wrangler Technical Forum 5 10-01-2010 08:25 AM
DEATH to the death wobble....wooohooo jeeperscreep04 TJ Wrangler Technical Forum 6 09-19-2009 02:31 PM
Steering Wheel Wobble. Not Death Wobble. bigbarr TJ Wrangler Technical Forum 1 05-29-2007 01:29 PM
is it death wobble or death steer frank_frank139 TJ Wrangler Technical Forum 4 03-06-2007 12:56 PM
