DEATH to the death wobble....wooohooo - JeepForum.com
post #1 of 7 Old 12-03-2006, 02:14 PM Thread Starter
jeeperscreep04
hey jeepers...have an 04 TJ, its my daily driver and my weekend funmobile. Had the major death wobble and got tips from all of you here, all over actually (everybodies got an opinion!) even some crap ideas for quick fixes. This was especially frustrating cuz I would be flying down the freeway with no problems at all and then all of a sudden it would go into convulsions. Other times I'd be going 45 in town and wham, there it goes, all freaking out...this made it very hard to pinpoint anything. Since my mechanic (the free one my ex-husband) lives over 100 miles away it took us a while to figure it out. Dont know if it was a single fix or a combination of them all but heres the list of all that was done and a big for it being over...
1: Dropped pitman arm (nope, previous owner didnt get one installed when the lift was put on)
2: eccentric cam bolts (didnt have these on from previous owner either)
3: Adjusted toe/caster
4: Balanced/Ailigned wheels (hate to say this to some of you that swear THIS is the fix but it did nothing for my TJ)
5: replaced bushings....ALL over, to poly, including lift control arms bushings
6: last but not least >>>>>>and this is what I BELIEVE finally fixed it>>>>>>> Currie Tie Rod System...the stock one just didnt do it...
I will be moving to 33's in a month or so and may or may not have to go thru some of the adjustments all over again but at least I know what to check...I hope this helps some of you peeps out there....have fun wheelin...........
jeeperscreep04 is offline
post #2 of 7 Old 12-03-2006, 02:39 PM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
congrats on the fix
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #3 of 7 Old 12-03-2006, 03:22 PM
igofshn
Locked @ both ends
igofshn's Avatar
You will regret the poly bushings. You will be lucky to get a year out of them.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #4 of 7 Old 12-03-2006, 03:25 PM
James04TJ
James04TJ's Avatar
More than likely the problem here was the stock TREs.
On a related note, after replacing every part of my TJs front end, the only fix to my DW issues was to set my toe 1/16" out.
*2004 TJ (Mine)* 1984 CJ-7 Buggy Project (Mine)* 1977 CJ-7 (Hers)*2005 Nylint Crawler (The Kid's)
James04TJ is offline
post #5 of 7 Old 12-03-2006, 10:59 PM
Border Dave
Got Sand?
Border Dave's Avatar
jeeperscreep04, how much lift do you have? Do you have a drop bracket for your upper track bar mount? If not, you are going to get bumpsteer from that drop pitman arm, since the track bar and drag link have to be parallel in order to maintain proper steering geometry.
Border Dave is online now
post #6 of 7 Old 12-03-2006, 11:08 PM
badtux
Tire chains on Unlimited
Oops. Didn't mean to post this here...
badtux is offline
post #7 of 7 Old 09-19-2009, 01:31 PM
corey4880
Hey guys had DW bad on my 03 tj I have a 2" lift and worn 31s put new 31x10.50s on after i've replaced everything on the front trying to fix it but after the new tires I'm going on a week and a half with no Dw
2003 Tj - 2.4l - 2"bb 31" ATs 15x10 American racing wheels- 4 Kc Daylighters- all new audio- 1800w kenwood amp 10" sub- Chrome chrome and more chrome-
corey4880 is offline
Solution to steering wobble and death wobble...need help Sparty TJ Wrangler Technical Forum 5 10-01-2010 07:25 AM
Steering Wheel Wobble. Not Death Wobble. bigbarr TJ Wrangler Technical Forum 1 05-29-2007 12:29 PM
is it death wobble or death steer frank_frank139 TJ Wrangler Technical Forum 4 03-06-2007 11:56 AM
Death Wobble help richnev TJ Wrangler Technical Forum 18 10-02-2006 07:13 AM
death wobble jerzeyjeep TJ Wrangler Technical Forum 4 09-30-2006 05:53 PM
