Dead Jeep! Electrical/Fuse Issue?? - JeepForum.com
post #1 of 4 Old 05-23-2010, 07:57 PM Thread Starter
malo8899
So I got in my jeep today, turned the key to acc and everything turned on, then tried to start the jeep and everything went dead. Turned the key back and forth and everything is off, dead, no power anywhere. Opened the hood, tapped on and jiggled the fuses and tried again. Turn to Acc, everything turns on, try to start, dead! Third time jiggling the fuses I got it to start.
Any guesses?
-mike
malo8899 is offline
post #2 of 4 Old 05-23-2010, 08:27 PM
bruteboy
clean your battery connections
bruteboy is offline
post #3 of 4 Old 05-23-2010, 10:37 PM Thread Starter
malo8899
Are you referring to the acutal positve and negative connections on the battery? Any recommendations on what to use to clean the connections?
Thanks!
Mike
malo8899 is offline
post #4 of 4 Old 05-23-2010, 10:49 PM
bruteboy
yes.you can use hot water from the tap mixed with some baking soda.
you must disconnect the terminals and clean the contact surfaces.
a small wire brush or some emery cloth will work .
when disconnecting the battery,remove the negative terminal first.
when reconnecting the battery,install the negative terminal last.
make sure everything is turned off before connecting or disconnecting the battery.
bruteboy is offline
Jeep won't start now..electrical issue? 4wheel4real TJ Wrangler Technical Forum 15 08-08-2011 11:05 PM
88 Jeep wrangler sahara yj electrical issue w/ turn signal & brake lights chthonic YJ Wrangler Technical Forum 5 02-12-2010 11:16 AM
Dead Jeep - electrical issue - Alt / regulator / battery? CTKen TJ Wrangler Technical Forum 5 09-26-2008 06:03 AM
electrical issue with my jeep speedracer2536 YJ Wrangler Technical Forum 2 07-11-2008 02:05 PM
Jeep Died today - Electrical issue msavard TJ Wrangler Technical Forum 22 09-01-2006 01:50 PM
