Dead Heater - JeepForum.com
post #1 of 8 Old 02-03-2007, 09:36 AM Thread Starter
Forumpete58
Dead Heater
Starting yesterday my heater blower randomly cuts out. If I turn it off and turn it back on everything's fine. Anyone have any idea whats going on?
Thanks!
Matt
Forumpete58 is offline
post #2 of 8 Old 02-03-2007, 12:11 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
have you checked the connector that plugs into blower? may be loose
RnEmOvr is offline
post #3 of 8 Old 02-04-2007, 07:51 PM Thread Starter
Forumpete58
I haven't checked that, I have no idea where it is. Sorry I'm not that knowledgeable. Any other ideas??
Thanks!!
Matt
post #4 of 8 Old 02-04-2007, 07:57 PM
RnEmOvr
RnEmOvr's Avatar
look under passenger side dash may be something in that range loose, as for blower connection im not sure, another thing is pull HVAC controls and see if loose connector in there
RnEmOvr is offline
post #5 of 8 Old 02-05-2007, 12:03 PM Thread Starter
Forumpete58
Thanks for the help, I'll check it out!
post #6 of 8 Old 02-05-2007, 10:21 PM
paintballjerry
paintballjerry's Avatar
Mine does this too. It was the switch that controls the air direction (far right switch). On mine there is a three prong plug on the side of the switch, it is melted and burnt up. When I get the part no. from the stealership, I will post nos. and price. If it comes down to it, I'll just solder the wires directly to the switch.
<=== My Specs are there in my Profile!!!
Co-Ed Naked Jeeper Club Member #69
Originally Posted by charlescho
don;t ask here what MPG you will get with what tires etc, you will get your butt raped by the forum bullies
paintballjerry is offline
post #7 of 8 Old 02-06-2007, 05:27 AM
Jackle
mine melted the wires connecting to the vent selector switch too........when i pulled mine apart the green and black wires were toast.........you have to replace the vent mode switch....its about $25 at the stealer.......you can't put new connectors on and then plug into the old switch........the heat screws them up something horrible.............let me know what you guys find.....
Jackle is offline
post #8 of 8 Old 02-06-2007, 09:55 AM
4130jeeptj
4130jeeptj's Avatar
Flush your heater core.I've seen alot of issues out of them.Check wiring like everyone else said too.
4130jeeptj is offline
heater gone dead blurunner YJ Wrangler Technical Forum 17 04-01-2013 12:53 PM
95 Wrangler Heater Core Dead Huskers98 YJ Wrangler Technical Forum 5 01-20-2010 10:32 AM
YJ Heater Core and Heater Motor Replacement?? Boston Mangler YJ Wrangler Technical Forum 11 11-29-2009 08:31 AM
The Jeep!!! He Is Dead! D. E. D. Dead! ixl4 TJ Wrangler Technical Forum 8 02-16-2007 03:52 PM
Dead Gauges, FAQ Link Is Dead omnipseudo TJ Wrangler Technical Forum 2 05-01-2004 09:05 PM
