Dead Battery, replacing with Optima Yellowtop - JeepForum.com
post #1 of 39 Old 07-19-2010, 08:16 PM Thread Starter
yelset
I am looking at replacing my dead battery with a Optima Yellowtop, Part Number: D34/78. Has anyone used this battery and if so, are you pleased with the performance? I am thinking with the deep cycle it would be good for winching.
Thanks, Mike
yelset is offline
post #2 of 39 Old 07-19-2010, 09:04 PM
Tredloc
No Stay away from Yellow Top and go Blue Top. I had a yellow top and one time it was drained while using my winch it never regained its full strength. Maybe it was a bad battery but since I traded over to Blue Top I have never had any issues, plus it gives you an additional post with wing nut.
Just my 2 cents
Tredloc is offline
post #3 of 39 Old 07-19-2010, 09:07 PM
BYuen
BYuen's Avatar
BYuen is offline
post #4 of 39 Old 07-19-2010, 09:22 PM Thread Starter
yelset
Thanks
yelset is offline
post #5 of 39 Old 07-19-2010, 09:28 PM
APEDZ04LJ
i picked up a duralast gold, the waranty was three times as longer then the optima, and it has a bigger recharger (aka holds more) and for 40 bucks cheaper, i was told the only difference between the yellow top and duralast was optima is strong as crap cause its a jail bat.
APEDZ04LJ is offline
post #6 of 39 Old 07-20-2010, 08:23 AM
longbluerubi
I think I'll go with a Diehard Platnimun when I'm ready to replace mine (stock battery is over 5 years old, so will be soon)
'05 LJ Unlimited Rubicon
I6 4.0L manual 6-speed
OME 2.5" lift+Nitrocharger Sport shocks
1" BL, JKS adj front & rear trackbars, JKS discos
33" BFG A/T
longbluerubi is offline
post #7 of 39 Old 07-20-2010, 08:25 AM
little_Jeep
Anything that says Optima, has no place in my Jeep.
little_Jeep is offline
post #8 of 39 Old 07-20-2010, 09:29 AM
-dirt-
Me too.
-dirt- is offline
post #9 of 39 Old 07-20-2010, 09:56 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The Diehard Platinum 3478-DT (DT= dual terminal) is a great decision guys, you won't regret it. I'm done with Optima batteries, no more.
Getting
Jerry Bransford is online now
post #10 of 39 Old 07-20-2010, 11:26 AM
Divinitous
Disgruntled Jeepforum'er
Divinitous's Avatar
My yellow top never made it through a full winter. Near the end the jeep would even start slow after driving on the highway, stopping to get gas and leaving the lights on for the 2 minutes. I thought I was having grounding issues since I bought the "biggest and baddest" battery out there. Finally after checking the alternator, starter, and wiring I brought the yellow top to get it tested. Failed instantly.
Sears diehard is a beast. Must say it's never let me down, I've left the jeep on for hours with lights, radio, and haven't even noticed a difference. You won't be disappointed.
-Ryan
Google Voice (or the number Grape calls when drunk): 845-476-8182
Originally Posted by Enzo Ferrari
"The Jeep is Americas only real sports car!"
Originally Posted by MrBlaine
"Jeeps do not make jeepers, jeepers make Jeeps."
Divinitous is offline
post #11 of 39 Old 07-20-2010, 11:31 AM
Sundowner
Between myself and a friend, we've had six Optimas die on us, now...reds, blues, yellows. I will NOT have another Optima in a vehicle. Diehard is a good battery...I've also heard nice things about Napa's in-house stuff.
Sundowner is offline
post #12 of 39 Old 07-20-2010, 12:45 PM
Jerry Bransford
Administrator
Just so you know, Optima's D34M Blue Top is the exact same battery internally as the 34/78 Yellow Top is... there is no electrical difference between them. They just have different case colors and connector styles.
Getting
post #13 of 39 Old 07-20-2010, 01:09 PM
Sundowner
At last! I KNEW that there was a reason the blue died as quickly as the yellow!
post #14 of 39 Old 07-20-2010, 02:12 PM
zachjf
I'd go with an Orbital battery and am planning on it when my current one dies, nothing good has been produced by Optima in a long time.
Needs parts?
PM
or
zachjf is offline
post #15 of 39 Old 07-20-2010, 02:21 PM
little_Jeep
I got the Deep Cycle 34XCD... it has been a great battery.... However, it was $219.00 out the door
optima , yellowtop , yellow top , battery , replace , replacement , TJ
Optima Battery digizure YJ Wrangler Technical Forum 22 10-29-2010 01:30 PM
00 TJ 4.0, dead Optima won't charge, push start? jage TJ Wrangler Technical Forum 10 12-10-2009 03:46 PM
battery dead ....argh... dual battery setup???? asjeep TJ Wrangler Technical Forum 21 07-20-2009 06:46 AM
Installing Optima Yellowtop WheelinTJ2004 TJ Wrangler Technical Forum 3 09-13-2005 01:13 AM
just installed yellowtop optima KY TJ TJ Wrangler Technical Forum 1 12-19-2004 01:31 PM
