Quantcast dead battery, but won't take a jump start??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > dead battery, but won't take a jump start???
Front and rear Drive shafts @ free shippingPoison Spyder February Special: FREE Rubber Liners when yoSlappin' on 61,510 Rigid Industries Lumens for Big Red
Old 05-04-2009, 09:47 PM   #1
O2GO4LO
Ok, first the background, Vehicle sat after a off roading trip without driving it for about 3 weeks. turns out that I left the FM transmitter (MP3 player) on. Stupid, I know. So I took the battery in, trickle charged it, load tested it, tested fine and all SEEMED to be ok.
Today, jumped in it, started fine, driving a minute or two after I left, " check guages" comes on.....the voltmeter was pegged out at over 19!!! I immediately turned off the road and shut it down..... turned the key back on and "bump started" it, as I was still rolling. Would not stay running.
Got under the hood, and from the black box (by the stock air box) was a rapid clicking sound (fuel pump relay I think) Called wife for a jump, after 30 minutes and multiple attempts vehicle would not do more than BARELY turn over, then nothing.
NOT ELECTRICALLY MINDED, but mechanically capable.....so, where do I start???
Side note: my neighbor (JEEPER) pulled me home!!! tow straps are not just for off-road!!
http://www.jeepforum.com/forum/f9/tj-tech-boot-camp-must-read-new-tj-owners-forum-members-722109/ <---- TJ boot camp...A MUST READ!!!
Been there and back, and always in a JEEP!
Black Jeep Society Member #45
San Diego Jeep Owners Club Member #33
O2GO4LO is offline   Reply With Quote
Old 05-04-2009, 10:41 PM   #2
Rayvins
Just a guess, however sounds like a bad alternator. Not recharging the battery, so the jeep runs til the battery dies again.
Do your lights or anything else work?
Rayvins is offline   Reply With Quote
Old 05-04-2009, 10:43 PM   #3
dudeinatj
when my check gauges light came on and voltmeter pegged, it turned out to be a ground problem.
dudeinatj is offline   Reply With Quote
Old 05-04-2009, 10:43 PM   #4
compcrasher86
RIT Offroaders
compcrasher86's Avatar
check your connections to the battery. Make sure they are clean, free of corrosion, and tighten them down. weird things happen when your connectors are bad
01 WJ Ltd - i6 - QT2 - OME 2.75" Lift - Bilstein 5100s - Dueler AT RHS 255-70-18 (32") - JK Sahara rims - ARB Front Winch Bumper - C4x4 Fab rear tire carrier bumper - Upcountry Skids - Tow Package - KC Dayliters Long Range - Cobra 19 - Boston Acoustics Speakers
Build Thread
RIT Offroaders
Matt
compcrasher86 is offline   Reply With Quote
Old 05-04-2009, 10:48 PM   #5
dudeinatj
that's what happened to me, left me stranded briefly until i figured it out.....a loose ground at the battery.
Old 05-04-2009, 11:17 PM   #6
O2GO4LO
Bump....c'mon guys.....I need a place to start...
http://www.jeepforum.com/forum/showthread.php?t=722109 <---- TJ boot camp...A MUST READ!!!
Old 05-04-2009, 11:22 PM   #7
TMar
People have given you places to start.
Are the cables tight?
Check your grounds.
Have your alternator checked
In that order.
TMar is offline   Reply With Quote
Old 05-04-2009, 11:38 PM   #8
O2GO4LO
thanks all... I hadn't refreshed my page when I bumped.....I'll get back on it tomorrow. I'll start with cleaning and re-tightening the connections...
Old 05-04-2009, 11:46 PM   #9
mikeb683
to be honest sounds like the alternator to me i had the same thing happen to me recently was and xj. But it came out of no where not my rig.. but we drove it about 100 miles no problems. Let it sit for 20 30 minutes tried to start it and nothing.. jumped it ran fine, which is different from you, but i got it up the road about two miles and the gauges started shorting on me and she eventually died only to be jumped no problem again. Anyway we later discovered it was the alternator as she is and electronic ignition just like the tj.
mikeb683 is offline   Reply With Quote
Old 05-05-2009, 12:42 AM   #10
O2GO4LO
OK....so I couldn't wait until morning, multimeter in hand, I just went to check into the problem. Battery = 12.4 volt (not running) Connections = 11.1 Cleaned connections, re-tightened, ta-da! starts right up. To be honest, I feel kind of stupid. When it comes to electrical problems, I just seem to shut down. Thanks again to all that posted. I love this place!!!!
FYI: I did the alternator test after I got it started again(read elsewhere on this forum,) and that was good at about 14.1 volts!!
Old 05-05-2009, 12:50 AM   #11
4x4grey88
ROCK WHEELER
4x4grey88's Avatar
14.1 volts is okay/normal
Do you post in the San Diego section??? There are a bunch of us Jeepers in the San Diego section posters on Jeep forum.
___________________________________________
In or Near San Diego, CA? Click Here
Black Jeep Club Member #1016
Senior Member: Jeep Repair Club, San Diego Chapter
4x4grey88 is offline   Reply With Quote
Old 05-05-2009, 12:56 AM   #12
mikeb683
Great.. glad we could help and glad my diagnosis of the **** alternator was wrong
Old 05-05-2009, 04:01 PM   #13
compcrasher86
RIT Offroaders
I knew this one from experience. My ZJ was stuck in a parking lot at school and had same exact symptoms as you. wiggled clamps to get it working and drove it home I literally had cracks through my connectors though (dont worry I replaced them)
Build Thread
RIT Offroaders
Matt
Old 05-05-2009, 05:14 PM   #14
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
When the battery is completely dead, the engine won't run long after being jump started and it can't be push-started either. There MUST be a good solid 12 volts from the battery to provide the alternator its required "tickler voltage" which makes it work. When there's no 12 volts from the battery at the alternator, the alternator won't work and the engine won't run.
Yes, SOME other alteranators and all generators work fine when there's no battery or if the battery is dead but that isn't true for the type of alternator used in modern Jeeps.
Charge the battery fully and then everything should be fine if the battery is in otherwise good condition.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Glock Forum
