Dead 4 banger. Time for a motor swap - Page 2 - JeepForum.com
post #16 of 18 Old 07-30-2010, 06:04 PM
cj847
Originally Posted by Wheelin98TJ View Post
Is there a version of the 545rfe that the 231 does not bolt up to?
I would think they all have the same common 6 bolt pattern that is used in all Jeeps and Dodges.
Hey wheelin. I'm curious why you wouldn't recommend buying a wrecked WJ (you can get them around here for cheap) and do the 4.7 and 545 as a set (plus you'd have other stuff like WJ brakes for free you could work on). Was that swap too much effort?
I am curious about how much if any problems you had with alarm stuff.
97 TJ Sport OPJ project (other peoples junk) I can't remember the last time I bought a new part.
cj847 is offline
post #17 of 18 Old 08-01-2010, 05:33 AM
emev0l
I worded that horribly, I meant a 4x4 RAM, good catch, that woulda confused a lotta people.
It is the same exact trans in a jeep.
People are just going to want to get one out of a 4x4 instead of a 2x4 because they will have to remove the tail shaft and try and hunt down a transfer case adapter for the trans.
There's a lot of these used transmissions out there, most of them are really cheap.
2001 TJ 4.6 Auto 4.5" AEV suspension 35's
2002 TJ 4.0 Manual 3" BDS suspension 33's
1987 Chevy 1 Ton 12" suspension 44's
1970 Cutlass 442 468CID TH400
1999 7.3 Powerstroke
emev0l is offline
post #18 of 18 Old 08-01-2010, 02:23 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
The swap was quite a PITA because of the wiring. The wiring section in the WJ FSM is 1,200 pages.
I think I would do a Ford 5.0 V8 if I were to do it again just because they wire up so much easier.
The Sentry key security is not difficult to work with if you have the donor vehicle.
If you're not afraid of wiring, then I'd say go for a wrecked WJ. In the end, I'm very pleased with how it turned out. It was just a long road to get there.
Wheelin98TJ is offline
engine swap , tj , wrangler
Motor Swap time viper21700 YJ Wrangler Technical Forum 0 05-18-2010 04:06 PM
XJ motor tranny swap in to 4 banger TJ Dragnz24 TJ Wrangler Technical Forum 1 06-03-2008 02:57 PM
Ran into a DEAD END trying to do a motor swap...Please Help Mandngo YJ Wrangler Technical Forum 5 05-29-2008 12:55 PM
Another Dead 4 banger...help. Evan Matthews YJ Wrangler Technical Forum 1 12-02-2005 12:11 PM
Help! Lift and Motor mounts on a 4 banger Tylenol7 TJ Wrangler Technical Forum 6 05-21-2004 03:40 PM
