Daystar EVS Shock Bump Stop Review - JeepForum.com
post #1 of 7 Old 07-24-2010, 03:43 PM Thread Starter
Landrobert
Installed a set of these {RED} soft Shock bump stops.
I have 5 inches of up travel shocks on 14 inch Bilstein 5150s running on an 2006 Jeep TJ with Rubicon Express Long Arm and 35 inch Toyo Tires.
First tests reveal a superb soft takeoff and landing on medium and hard bumps and do not intrude in everyday driving.
Will post later on durability to everyday and offroad use.
Daystar
Do not worry now! Landrobert is here.........
Landrobert is offline
post #2 of 7 Old 02-27-2011, 11:55 PM
BlackSCRunner
Any update on these? Thanks!
BlackSCRunner is offline
post #3 of 7 Old 02-28-2011, 10:25 AM Thread Starter
Landrobert
Daystar bump stops work great! Nonetheless they are breaking appart......They are good for 1 year........I plan to upgrade to hydraulic Bumpstops soon.
post #4 of 7 Old 02-28-2011, 12:47 PM
BlackSCRunner
Cool, for $20 a pair I'll give them a shot!
post #5 of 7 Old 05-14-2011, 10:41 PM
Tyler99TJ
Did you install these? If so, how do you link them?
Tyler99TJ is offline
post #6 of 7 Old 05-14-2011, 11:13 PM
pdangerp
pdangerp's Avatar
Seems like this would add stress to the mounting bolts for the shocks. Have you had any broken bar pins?
pdangerp is offline
post #7 of 7 Old 05-15-2011, 08:27 AM
BlackSCRunner
I TRIED to install them. I spent hours and gave up. Heat, lube, brute force, even with the install tool I couldn't get them to slide over my shocks. I'm not one to give up easy, but I just decided that it wasn't worth it to continue. Maybe I got an extra hard set, or maybe the shocks I used were wider at the top than usual, but I was very disappointed in these. I wouldn't recommend them, though I can't comment on how they work once they are installed.
daystar bumpstops , bumpstop
Are Daystar bump stops too long for 2" BB? gs2offroad TJ Wrangler Technical Forum 3 12-07-2010 11:11 AM
Need Shock & ACOS Pro or Teraflex Bump Stop Advice Woodchuck JK Wrangler Technical Forum 5 01-20-2010 01:56 PM
Bump stop extenders pushing past Bump stops. KraZeDav YJ Wrangler Technical Forum 5 09-12-2009 03:57 PM
Daystar Tailgate Bump Stops? SETXWarrior JK Wrangler Technical Forum 4 08-18-2008 02:52 PM
bump stop asjeep TJ Wrangler Technical Forum 2 09-23-2002 11:32 AM
