Dashboard/electronics problem with TJ 97' - JeepForum.com
post #1 of 7 Old 06-14-2012, 01:39 PM Thread Starter
carlos0306
Jeep Wrangler 1997 2.5L
After playing around and re-wiring my sub i went to turn the car on and i am not sure what i did but all the gauges (speedometer, RPM, temperature, gas) all of them as well as my radio have no power.
The car still turns on and runs perfectly. All the lights work around the car. Horn still honks. If gas is low the light turns on in the dashboard
I have checked the main fuse box and all are good.
What else should i check?
Any help will be very helpful.
Thank you,
Carlos
carlos0306 is offline
post #2 of 7 Old 06-14-2012, 04:24 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Did you check the other fuse box? The block behind the glove box? I think the gauges are fuse 10 & the radio is 15 I believe.
Rubi4MyMrs is offline
post #3 of 7 Old 06-15-2012, 04:48 PM
jlaudio_jeep
I have this same problem! I got in my jeep to leave and all my gauges and radio are dead. They worked fine before I put a new brake light fuse in. Now I have nothing and ALL my fuses are good! I need my jeep now!
jlaudio_jeep is offline
post #4 of 7 Old 06-16-2012, 04:44 AM
Jonny Jeep
Jonny Jeep's Avatar
Carlos, do you have courtesy lamps below the dash or dome lamp or under hood lamp? If you do and they are out then it's likely to be the fuse in the PDC. Those lamps get power from the same fuse as the radio and cluster in the under hood power distribution center - fuse 17 (10 Amp). Even if it looks good try swapping it out I've seen fuses before that look fine but test bad.
If the fuse is OK it's possible there is a break in the wire somewhere on the way into the tub. Check for power at the pink/white wire at any of the lamps, radio or cluster.
If the lamps work the fuses rubi lists are correct for switched power. I doubt it's a switched problem though as the radio and cluster get power from different contacts within the switch and wipers, turn signals and accessory socket would be dead too.
Jonny Jeep is offline
post #5 of 7 Old 06-16-2012, 04:48 AM
jlaudio_jeep
I found my problem. I was checking all my fuses the day before and I forgot I dropped one. It was the iod fuse. Works fine now.
post #6 of 7 Old 06-16-2012, 12:36 PM Thread Starter
carlos0306
Thank you
Thanks a lot guys it was that fuse 17 for some reason i thought those small ones weren't going to run those electronics so i didn't check them. once again thank you.
post #7 of 7 Old 07-27-2012, 09:17 PM
michjeeper
Thanks guys!! Helped me out too(fuse 17)
michjeeper is offline
dash board problem , electric , radio
electronics in my 07 gregkelley JK Wrangler Technical Forum 3 01-25-2011 08:50 PM
Help. my electronics are getting wet and so em I GranadeYJ YJ Wrangler Technical Forum 15 12-04-2007 05:08 PM
Help Please! Electronics FourShotJohn TJ Wrangler Technical Forum 4 10-04-2007 05:58 PM
Stuck with flasher electronics problem jel21 TJ Wrangler Technical Forum 2 04-17-2006 02:30 PM
Problem with my dashboard virgil_likes_rum TJ Wrangler Technical Forum 8 07-12-2002 12:31 PM
