Dash Vents Question - JeepForum.com
post #1 of 5 Old 11-20-2009, 08:27 PM Thread Starter
Eric2000TJ
Dash Vents Question
Here's one for someone to figure out. When I turn on my heat or A/C it only comes out the defrost vent and bottom vent. For the first time (I've had my TJ for 7yrs) after I had the A/C on for a while this summer it started to come out the center vents as well. Once I turned it off it stopped and went back to the def. and bot. vents again. It has also done this with the heat. Why doesn't the air want to come out of the center vents too? Anyone?
Eric2000TJ is offline
post #2 of 5 Old 11-20-2009, 09:04 PM
-dirt-
http://www.jeepforum.com/forum/f9/al...roster-527339/
Check the pic in post #5. Vacuum hose on the driver's side of engine.
-dirt- is offline
post #3 of 5 Old 11-21-2009, 12:53 PM
BlueFlame
BlueFlame's Avatar
Common well known issue - vacuum leak.
(there's a search button......)
BlueFlame is offline
post #4 of 5 Old 11-21-2009, 04:19 PM Thread Starter
Eric2000TJ
I'm glad I found this forum, because I am learning a heck of a lot of stuff! Everyone's help and knowledge is greatly appreciated!!!
post #5 of 5 Old 11-23-2009, 07:23 AM
-dirt-
This fix it?
-dirt- is offline
Removing Dash Vents BradG TJ Wrangler Technical Forum 11 12-16-2013 11:18 PM
dash air vents sandman'sjeep YJ Wrangler Technical Forum 12 08-17-2012 03:38 PM
Dash Vents No A/C KilgoreTrout TJ Wrangler Technical Forum 3 08-04-2009 09:24 AM
97 tj no air out dash vents 97tj1990jeeper TJ Wrangler Technical Forum 1 03-10-2009 04:11 AM
dash vents mikev TJ Wrangler Technical Forum 3 04-18-2003 09:10 PM
