Dash Vents No A/C - JeepForum.com
post #1 of 4 Old 08-04-2009, 09:36 AM Thread Starter
KilgoreTrout
Dash Vents No A/C
I just noticed that my dash vents don't blow air. I've got a starting point thanks to some threads here, but before I get started, are dash vents supposed to work if you don't have A/C? For reference, I have an '01 TJ with no A/C. I read on another forum that on older Wranglers the dash vents only worked if you had A/C. Is that still true?
KilgoreTrout is offline
post #2 of 4 Old 08-04-2009, 09:47 AM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
Mine did on my old YJ.
TheBoogieman is offline
post #3 of 4 Old 08-04-2009, 09:57 AM
Scotch740
Scotch740's Avatar
Do all your other vents work?
If it only blows out your defrost try this.
http://www.jeepforum.com/forum/f9/fan-always-blows-defrost-selector-doesn-t-work-830241/
But to answer your question yes even if you dont have AC your dash vents should still work.
Scotch740 is offline
post #4 of 4 Old 08-04-2009, 10:24 AM Thread Starter
KilgoreTrout
Haven't checked defrost vents yet. But my floor vents definitely work. Thanks for the answer on the dash vents. I'll check the engine bay hose first before I go crane my neck and swearing a storm trying to look underneath the dash.
dash air vents sandman'sjeep YJ Wrangler Technical Forum 12 08-17-2012 04:38 PM
Dash Vents Question Eric2000TJ TJ Wrangler Technical Forum 4 11-23-2009 08:23 AM
97 tj no air out dash vents 97tj1990jeeper TJ Wrangler Technical Forum 1 03-10-2009 05:11 AM
Looking for dash vents? Know a web site? BChamberlin TJ Wrangler Technical Forum 6 06-10-2008 01:44 PM
dash vents mikev TJ Wrangler Technical Forum 3 04-18-2003 10:10 PM
