dash vents - JeepForum.com
post #1 of 4 Old 04-18-2003, 06:19 PM Thread Starter
mikev
dash vents
I am unable to get air out of the dash vents on my '97. Had this problem when jeep was still under warranty. They replaced some kind of broken lever??? Still get air on windshield and on floor. Any ideas?
mikev is offline
post #2 of 4 Old 04-18-2003, 08:01 PM
davebelair
Hey, I had that problem with mine when I bought it. I negotiated the fix before I bought it though. Thank God cause it is a major repair If it is the door in the vent. they have to remove the dash, a/c, wiring harness at least that Is what I was told. I would try to get the dealer who fixed it, fix it again. what is it with the heater a/c system I know someone else who's vent is screwed up also...
Anyway good luck with it
davebelair is offline
post #3 of 4 Old 04-18-2003, 09:04 PM
motox851
You should do a search in the forum. There has been a few different threads about this with quite a few ideas of what could be wrong.
Without Struggle there is no progress.
motox851 is offline
post #4 of 4 Old 04-18-2003, 09:10 PM
Tango
Tango's Avatar
before you go tearing apart the dash check your vacuum hoses they are under the dash on the driver side .....I knocked mine off when I installed my first CB and I was unable to get air out of the dash vents but still got air on windshield and floor.
Here is a picture of the hoses I am talking about.
these are at the bottom
These are at the top
good luck Hope this helps
02 TJ 4.5" of lift , Locked Both ends, with 4.56's pushing 33X12.50 MTR's
Tango is offline
Removing Dash Vents BradG TJ Wrangler Technical Forum 11 12-16-2013 11:18 PM
dash air vents sandman'sjeep YJ Wrangler Technical Forum 12 08-17-2012 03:38 PM
Dash Vents Question Eric2000TJ TJ Wrangler Technical Forum 4 11-23-2009 07:23 AM
Dash Vents No A/C KilgoreTrout TJ Wrangler Technical Forum 3 08-04-2009 09:24 AM
97 tj no air out dash vents 97tj1990jeeper TJ Wrangler Technical Forum 1 03-10-2009 04:11 AM
