Dash Squeak Fix! - JeepForum.com
post #1 of 10 Old 03-08-2012, 07:28 AM Thread Starter
05TNRubi
Dash Squeak Fix!
I have been chasing a squeak behind the dash for weeks. It has sounded like I have a nest of baby birds just behind the radio. I removed the radio and drove around till the squeak started so I could reach in the dash and stop the squeak with my hand. What I found was the air duct for the defrost that is molded to fit along the fire wall was rubbing the fire wall. I shoved larges pieces of rubber between the two and some foam and now NO SQUEAK! I hope this helps anybody that is searching.
05TNRubi is offline
post #2 of 10 Old 03-08-2012, 10:22 AM
CrimeSScene
Been living with the same sound for months...I'll be giving this a try tonight!
CrimeSScene is offline
post #3 of 10 Old 03-08-2012, 10:35 AM
Delta9
Delta9's Avatar
Thanks! It only happens every once in awhile, but it's annoying. Hopefully this is my problem.
Delta9 is offline
post #4 of 10 Old 03-08-2012, 11:24 AM
SideshowBob024
saved for later.
SideshowBob024 is offline
post #5 of 10 Old 03-08-2012, 11:27 AM
JBTJ
Mine did that too once. I got a can of that spray expanding foam and sprayed some behind the duct work. No more squeaks.
JBTJ is offline
post #6 of 10 Old 04-08-2012, 09:35 PM
willatthe4077th
I've been dealing with the same thing, finally fixed it today. Underneath the long plastic pannel that covers the vents along the inside of the windshield (you can remove it by prying it off) there are two m6 nuts on either side of the steering wheel that hold the driver's side of the dash in place. The one on the right side was totally missing (I have no idea why) but I replaced it, with a washer too, and NO MORE SQUEAK! AND no more jiggly dash either, didn't realize how bad it was until it stopped.
willatthe4077th is offline
post #7 of 10 Old 04-08-2012, 10:17 PM
StvDiego
I spent the weekend chasing a squeak, found this, an old Sirius radio tuner from the original owner:
StvDiego is offline
post #8 of 10 Old 04-08-2012, 11:14 PM
Sparkyman2000
Funny used to be a service bulletin for that called "Missing screw Bulletin" for that exact rattle. I have installed that nut about 1000 times.
I will start being nicer when you start being smarter.
Sparkyman2000 is offline
post #9 of 10 Old 03-28-2013, 09:01 AM
montanamule
Ok guys, straight up. I have a 2000 TJ sahara, 4.0L. I've been chasing a squeak that I thought was angry sparrows. Also thought it was this nut or the firewall vent. My friend found the problem. It was the shifter for the 4WD. It wasn't pushed down all the way. That produces a fairly annoying squeak!
montanamule is offline
post #10 of 10 Old 03-03-2017, 08:17 AM
SaltyDog2
Thank you montanamule!
I would have sworn that the squeak was deeper in the dash. I was gearing up to tear the dash apart this weekend, but now it is not necessary. A little grease on the 4x4 shift lever, an easily accessible part, and all is well.
1999 Wrangler TJ Sport 4.0 Automatic
SaltyDog2 is offline
2009 Dash Squeak Hemrides JK Wrangler Technical Forum 4 10-17-2011 11:08 AM
I have a bad squeak in my dash Red_Dawg TJ Wrangler Technical Forum 11 04-21-2009 07:23 PM
Help isolating squeak in dash when cold IAJack TJ Wrangler Technical Forum 2 01-30-2009 07:18 AM
Can't find Squeaky Squeak behind the dash???? GEM1N1 TJ Wrangler Technical Forum 7 01-24-2009 07:15 PM
Unidentifiable squeak behind dash board...driving me nuts! BlueJeepRME TJ Wrangler Technical Forum 30 10-08-2007 02:13 PM
