Dash speaker wires. which is - and which is +? - JeepForum.com
post #1 of 3 Old 10-28-2009, 11:08 PM Thread Starter
AlTheKillerr
AlTheKillerr's Avatar
so ones red with black (assuming its negative) and ones green. just wanted to double check before i screw something up
Photographer
2000 XJ, 3.5" lift, 32s, Locked
AlTheKillerr is offline
post #2 of 3 Old 10-28-2009, 11:53 PM
George Dickel
George Dickel's Avatar
According to the FSM for the 99 Wrangler:
18DG is Left front(+)
18BR/RD is Left front(-)
18VT is Right front (+)
18DB is Right front (-)
'98 Wrangler Sport, 4.6L Stroker
12 Counterweight 258 Crank (cut snout-casting #3214723), Sealed Power +.030 Hypereutectic Pistons, 5.875" Connecting Rods, CompCams 68-231-4, Ported/Polished Head, Edelbrock Header, 24# Ford Blue-top Injectors, 63mm bored OEM Throttle Body, Port matched Intake, Autolite Platinum plugs, Accel Coil, LiveWires Distributor & Wires, Centerforce Clutch, Hurst Shifter, modified Mustang GT Air Cannister - CAI, 18" Magnaflow and 2 1/2" exhaust, Balanced Rotating Assembly, Custom PCM tune.
Yeah, I built it!
Exhaust clip:
'04 Mustang GT, 4.6L
Light modifications
Read more, Post less, Search often
George Dickel is offline
post #3 of 3 Old 10-28-2009, 11:57 PM Thread Starter
AlTheKillerr
awesome thanks
Photographer
Myster dash wires, please help! InEmberClad YJ Wrangler Technical Forum 2 10-08-2009 03:09 AM
Getting at the speaker wires... Stiffler YJ Wrangler Technical Forum 5 03-12-2008 05:02 PM
what do i do about the speaker and lighting wires in the roll bars jeepman06 TJ Wrangler Technical Forum 6 02-18-2008 09:29 AM
Help!!! heater wires melted in dash Jackle TJ Wrangler Technical Forum 8 02-01-2007 10:09 PM
Wires to the top of dash sequel YJ Wrangler Technical Forum 5 01-24-2006 11:07 PM
