dash lights just went out, along with running lights, and tail lights. what happened
#1 | |
i just turned on my head lights like 2 nights ago and the whole dash cluster went out (but the functions light up), the ac controls, the tail lights (although brake lights work), and the orange side markers and running lights. i checked the cluster fuse and its fine. but basically all the stuff that require that 12v illumination just won't turn on. is that a switch thing, or a bad ground, i feel like i'm definately not the first person to have this problem.
any help would be awesome, thanks guys.
#2 |
Do the gauges still work and just the back lights are dead?
Or is everything out and not reporting.
Signatures are for attention whores. Oh the irony. |
#3 |
everything still works, everything is functioning. that annoying shift light still comes on, when i'm low on gas the light comes on. the airbag light and all that other stuff lights up when i turn it on. but when i turn on the head light switch the gauges don't illuminate, the tail lights don't turn on, the parking lights don't light up...however the head lights still turn on and the brake lights light up when i apply the brake. all the fuses are ok it seems.
#4 |
As the brake lights are still working fuse 4 in the PDC is OK. That supplies fuses 1 (dash/marker lights and immobiliser), fuse 2 (stop lamps) and fuse 3 (fog lamps) in the internal fuse panel.
I'd pull fuse 1 from the panel behind the fuse box and check it properly if you've not already pulled it. If the fuse is OK you may have a problem with the head lamp switch, or the wiring from the fuse panel to the switch. Check for live at the tan/black wire which is the feed from the fuse. The outputs for the external and dash lights are on different wires so I expect the problem is with the supply side.
"Giving English to an American is like giving sex to a child. He knows it's important but he doesn't know what to do with it." Adam Cooper (19th century) Rockauto 5% discount code can be found here... http://www.markviii.org/LOD2/products_services.htm Online factory service manuals can be viewed at http://www.jeep4x4center.com/knowledge-base/index.htm#service Parts list PDFs available from http://www.berrysprinter.com/jeepparts.php |
#5 |
i'll try that, thanks man.
#6 |
Johnny I would just like to say that this thread just fixed the same problem for me as I have just found a broken fuse #1. Thank you!!!!
#7 |
Good job Johnny jeep!! That fixed my issue as well. I didn't think that the parkling lamp fuse (#1) would have anything to do with giving fire to my dash lights, and HVAC lights. Learn something new everyday. Thanks
1997 TJ, 4.0, 5 Spd, Low miles, Rough Country 2.5" Suspension Lift, 3in body lift, Mega Short SYE and custom shaft, 33x12.50 Maxxis Bighorns, 15x8 Soft 8's, 8.8 Rear w/LS, HP D30 w/LockRight and 3.73's |
#8 |
mine is fixed as well.
#9 |
That happened to me last month. Fuses were fine, but I had no interior lights, no ac light or dash lights, nothing... if you still have an issue replace the knob that you pull out to turn on the lights. That's what I had to do and now its fine.
[FONT="Century Gothic"][COLOR="Blue"]A big THANK YOU to AmbuGrl and Mudvain for upgrading me. [/COLOR][/FONT] [COLOR="Purple"]Yes, I'm a girl, I drive a TJ and like to get it dirty. Yes, I like boys. Get over it. [/COLOR] [COLOR="Purple"]Live Fun, Ride Fast, Die Pretty ~ Chic Riders M[/COLOR] [QUOTE=vindicated;11072220] Did I ever mention I loved you? :kiss: [/QUOTE] [QUOTE=Sarahdactyl;11072442]Hey! That's my woman you're hitting on there! <:mad:> [/QUOTE] Be Jealous |
#10 |
In case any one reads this for info. I've recently answered someone else with this problem and noticed whilst referring to FSM that the power from the dimmer control goes though fuse 12 inside the Jeep before heading to the dash lamps. If you have front and rear marker lamps but no dash lamps check that fuse too.
#11 |
Restoration Complete
Thanks Jonny! 1 was fried and 12 was fine.
'98 Wrangler Sport, 4.6L Stroker 12 Counterweight 258 Crank (cut snout-casting #3214723), Sealed Power +.030 Hypereutectic Pistons, CompCams 68-231-4, Ported/Polished Head, Edelbrock Header, 24# Venom Injectors, 63mm bored OEM Throttle Body, Port matched Intake, Autolite Platinum plugs, Screamin' Demon Coil, LiveWires Distributor & Wires, Centerforce Clutch, Hurst Shifter, modified Mustang GT Air Cannister - CAI, 18" Magnaflow and 2 1/2" exhaust. Balanced Rotating Assembly. Yeah, I built it! '04 Mustang GT, 4.6L Light modifications Read more, Post less, Search often |
#12 |
Been a while since I have been on, but Jeepforum answered the quick question again! #1 was blown - the only fuse I did not check. Thanks guys!!!
2003 Rubicon, stock - but building - slowly... in Van Buren, AR |
#13 |
fuse 1 was my problem. Thanks!!!
#14 |
Hey guys im having the same problem.. fuse 1 is blown but keeps blowin every time i turn the power on.. what is the next step i should take?
#15 |
You might check and see if you have some corrosion. Sometimes that can blow the fuses.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
