dash lights help - JeepForum.com
post #1 of 21 Old 03-20-2011, 02:15 PM Thread Starter
bigpapparose
dash lights help
hi all
2003 tj se 2.4
so my dash lights have not been working for some time now. all fuses hav been checked and rechecked. the bulbs have been pulled from behind the dash and seems that all the lights at in good working order.
any one know any thing else it could be? i would love to see my dash at night.
sn. the instruments all work. ac works and radio. the lights to the ac controls are also out. i ride in pitch black darkness. dome lights work
bigpapparose is offline
post #2 of 21 Old 03-20-2011, 02:59 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Dimmer switch?...
Knuckelhead is offline
post #3 of 21 Old 03-20-2011, 03:17 PM
Neudiin
The connectors on the back of the gauge housing are tight when they are plugged in? And there is no contamination on the plugs?
Neudiin is offline
post #4 of 21 Old 03-20-2011, 04:03 PM
jpfelix
that's usually the first part to go on the headlight switch.
jpfelix is offline
post #5 of 21 Old 03-20-2011, 04:03 PM Thread Starter
bigpapparose
I have Twisted the dimmer switch however it only changed the odometer light, which is the only light that works except for the indicator lights ie 4x4, gas, brights, ect.
The connections on the back of the dash are nice and tight. No corrosion
post #6 of 21 Old 03-20-2011, 04:08 PM Thread Starter
bigpapparose
How can I check the headlight switch
post #7 of 21 Old 03-20-2011, 04:18 PM
jpfelix
do you have a multimeter &/or test light?
jpfelix is offline
post #8 of 21 Old 03-20-2011, 04:19 PM Thread Starter
bigpapparose
Yes i do
post #9 of 21 Old 03-20-2011, 04:25 PM
K1dS3ns4t10n
This same thing happened to me on my 97. I took the headlight switch out and shot the exposed dimmer contacts with contact cleaner and its been working fine ever since.
K1dS3ns4t10n is offline
post #10 of 21 Old 03-20-2011, 04:54 PM Thread Starter
bigpapparose
Wont I need a special tool to take the steering wheel out?
post #11 of 21 Old 03-20-2011, 05:24 PM
Knuckelhead
AFSOC Retired
Filling in your profile would help...
BIGPAPPAROSE'S JEEP
User Has Not Filled Out Jeep Information.
post #12 of 21 Old 03-20-2011, 05:38 PM
K1dS3ns4t10n
The headlight switch on my 97 is the dash mounted pull-out type switch, so removing the steering wheel was not needed.
I'm not familiar with the 2003 dash set up, but I'm assuming based on your question that the headlight/dimmer switch is mounted on the turn signal stalk?
post #13 of 21 Old 03-20-2011, 06:20 PM Thread Starter
bigpapparose
Sorry about the profile fill out. Couldn't remember my password and needed help so I through out a new profile on my iPhone.
Omgyesihavethos is the account I believe :/ not sure cause I haven't been on jf in a while.
The turn signal, headlight, dash dimmer is steering wheel mounted of course. 90$ piece. Wasn't looking forward to buying it. Luckily, discount auto took the choice away from me by not having any in stock. Lol.
I tried to check for any electricity with a voltmeter. Everything checked out so no shortages. I'm guessing I will have to actually replace the headlight switch ?
Any other ideas? I used up the whole day off to fix this with no luck.
post #14 of 21 Old 03-20-2011, 06:38 PM
Knuckelhead
AFSOC Retired
PM one of the forum moderators for help, or refill in your information?...
post #15 of 21 Old 03-20-2011, 09:20 PM Thread Starter
bigpapparose
just got on the laptop.. filling in the profile
dash , instrument , instrument cluster , light dash electrical
dash lights just went out, along with running lights, and tail lights. what happened bortz1892 TJ Wrangler Technical Forum 50 09-04-2016 05:33 AM
89 YJ Electrical Issues blinkers/ dash lights come on with Brake lights Cajun90YJ YJ Wrangler Technical Forum 9 10-03-2010 05:33 PM
Headlights and dash lights don't turn on, but the amber lights do mniemela YJ Wrangler Technical Forum 1 06-10-2010 04:11 PM
Running lights and Dash lights wont work!? Help nield13 YJ Wrangler Technical Forum 4 12-12-2009 02:22 PM
2000 Wrangler No park Lights or Dash Lights Deb04 TJ Wrangler Technical Forum 2 04-06-2004 10:28 PM
