is it just the dash lights or do the gauges go out when you are driving?
my light switch has been acting weird. headlights will be off but dash lights are on. sometimes dash lights are on but headlights are off. sometimes both are off when the switch is pulled all the way out. if i pull the switch in and out a few times everything will work. i am sure my dash light switch needs to be replaced. maybe yours does too.
ya my headlights work but all the gauges are dark except the brake light on the dash..and when i turn by light knob my floor lights will still turn on but still nothing on the dash.
It might be fuse number 1 behind the glove box but I can't be sure until I know what model year your TJ is. Fill in your profile with as much detail as possible and it will help people answer your questions.
Fuse 12 gets it's supply from fuse 1 via the ignition switch so if you ever loose dash lights again and it's not fuse 12 check your front and rear marker lights. If they are out it's fuse 1.
Thanks for filling in your profile.:thumbsup:
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
