Dash fan not working - JeepForum.com
post #1 of 9 Old 08-30-2007, 08:09 PM Thread Starter
gm77979
The dash fan (AC/heater) would not come on today. It now will only work on the forth speed (high).
Any ideas on what is wrong or how to diagnose the problem.
2003 Wrangler 13,000 miles
Thanks
Glen
gm77979 is offline
post #2 of 9 Old 08-31-2007, 05:15 AM
kloppk
A bad blower motor resistor will cause this.
A very common problem. They are easy to replace.
kloppk is offline
post #3 of 9 Old 08-31-2007, 07:59 AM
halfmoonclip
The usual diagnosis for losing fan speeds is a failed resistor. The resistor steps down the voltage to slow down the fan. Speed four is 'no resistance', so it continues to work.
The resistor is located behind the glove box, and is a relatively cheap and easy fix (ruling out the 'hanging upside down under the dash like a bat in the daytime' and getting the @^$#^%#^#^%!!!!! electrical connection to pop loose); part costs less than $20.
Do a search; there are great photos to help you find the resistor, which is a challenge in itself.
Moon
'04 Rubi, manual, usual options, Hella H-4s, any range lockers, Randy's booster seats, Oly pushbar, 245/75R16 BFG
'09 Audi A4 Avant- my bride's schnellpuffenpanzer
'12 Ford Focus-the sure way to get good Jeep mileage
'07 Dodge Caliber R/T AWD-da kid's ride
Goodbye Old Blue XJ; 10+yrs, 100K+ miles; virtually trouble free; Long may you run!
halfmoonclip is offline
post #4 of 9 Old 08-31-2007, 08:01 AM
EvilM0nkey
EvilM0nkey's Avatar
Moon
But you have to use the google search for now till we get our new servers
EvilM0nkey is offline
post #5 of 9 Old 09-01-2007, 02:02 AM
Rossta
Rossta's Avatar
Moon
Would this be the same diagnosis if speeds 1,2 and 4 work but not 3? This is the problem I am having with mine. I am guessing the answer is "yes", but my situation is slightly different from the OP's.
Rossta is offline
post #6 of 9 Old 09-01-2007, 07:47 AM
Woodyhfd
Leave your fan off until you fix this! The damaged resistor can cause the wires leading to it to overheat and melt, making the fix a bit more complicated.
"There's only two things in life, but I forget what they are." -John Hiatt
Woodyhfd is offline
post #7 of 9 Old 09-01-2007, 08:46 AM
flatlander757
Yep.
I'm missing my lowest speed fan, I really oughta get around to fixing that haha.
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline
post #8 of 9 Old 09-01-2007, 11:35 AM
halfmoonclip
Flatlander had the same issue I did; #1 was out, I'm not sure for how long, before I got around to fixing it.
So, yes, it's the same diagnosis.
Moon
post #9 of 9 Old 09-01-2007, 12:25 PM
Rossta
Rossta's Avatar
OK, thanks for the responses moon, flatlander and woody!
Rossta is offline
4x4 dash light not working mattpm07 TJ Wrangler Technical Forum 5 01-10-2011 11:34 AM
My dash lights are not working Plowhoss YJ Wrangler Technical Forum 2 02-24-2009 09:18 PM
Dash lights not working?? MUDDY94 YJ Wrangler Technical Forum 0 02-07-2009 07:35 PM
dash components not working lsucadi YJ Wrangler Technical Forum 1 08-27-2007 06:51 PM
4WD dash light not working MyRig is Yellow TJ Wrangler Technical Forum 2 04-09-2006 10:26 AM
