Dash cluster problems - JeepForum.com
post #1 of 7 Old 07-18-2007, 02:59 PM Thread Starter
spendit66
My dash cluster will go out and sometimes come back on. Has this happened to anyone else, and how do I fix it.
HELP!
spendit66 is offline
post #2 of 7 Old 07-18-2007, 03:05 PM
erickpl
erickpl's Avatar
Remove dash and clean the spade connectors to get junk off them. Make sure all are straight, apply dielectric grease, reinstall dash.
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline
post #3 of 7 Old 07-20-2007, 07:36 PM Thread Starter
spendit66
Thanks dude!
post #4 of 7 Old 07-20-2007, 08:41 PM
CypressJeep
I had the same problem and did exactly what Paul said and it worked. havent had a problem since!
CypressJeep is offline
post #5 of 7 Old 07-20-2007, 09:26 PM
marc1kim
Chrysler has a technical service bulletin on the matter. Apparently there's erratic airbag light illumination, and sometimes the cluster goes dead. Cleaning the connector helps, but the problem may return at a later time. Here's more information on the TSB:
NO: 08-15-99
SUBJECT: Erratic, Intermittent Cluster Operation/Intermittent Air Bag Warning light.
DATE: May 21, 1999
OVERVIEW:
This bulletin involves installing a repair harness containing a revised instrument cluster connector.
SYMPTOM/CONDITION:
Some vehicles may exhibit an intermittent illumination of the air bag warning light or an intermittent tachometer or speedometer drop out. An Airbag Electronic Control Module (AECM) fault code -"No Cluster CCD BUS " message will be present.
DIAGNOSIS:
This condition is caused by minor oxidation of the BUS circuit terminals at the instrument cluster connector. Electrical terminals will show signs of oxidation, which will appear as darkened lines or marks on the cluster male terminals. These often appear as gray or black marks rather than the appearance of oxidation or corrosion usually associated with higher current carrying circuits. THIS TECHNICAL SERVICE BULLETIN WILL NOT ADDRESS FUEL OR OIL PRESSURE GAUGE ISSUES.
PARTS REQUIRED:
Part No. Description
105016261AA Cluster Connector Patch Harness
104856975 Electric Contact Cleaner
204778570 Heat Shrink Tubing
REPAIR PROCEDURE:
Disconnect the negative battery cable.
Remove the instrument cluster using the procedures outlined in the appropriate servicemanual.
Inspect the male terminals of pins 1 & 2 on the instrument cluster connector labeled CNB. The oxidation will appear as gray or black lines or marks on the terminals. If any signs of oxidation are present, remove them by gently scraping the terminals with a small flat bladed screw driver until the oxidation is gone. Use of a magnifying glass may be helpful. Use caution when performing this operation. Do not apply excessive force to the terminals to avoid bending them or damaging the cluster or terminals. Do not use a sharp tool, knife or sand paper, which could remove the protective plating from the terminals. Do not use any cleaner other than p/n 04856975. Other chemical cleaners could damage the instrument cluster.
Clean the male terminals with Electrical Contact cleaner, p/n 04856975. Apply the cleaner sparingly holding the cluster with the connector facing down to avoid excessive amount of cleaner from entering the cluster.
Remove the green cluster connector from the bracket.
Using wire cutters, remove the instrument cluster harness connector from the harness. Remove only the connector containing the BUS circuit This connector is labeled CBA on the cluster. Cut the wires as close to the insulator as possible.
The new connector must be soldered onto the harness. This operation requires a technician who is skilled at soldering to avoid a cold solder joint. Position the harness and align the wires with the patch harness, matching the color codes match the main wire colors. NOTE: THE XJ INSTRUMENT PANEL CONTAINS ONE MORE CIRCUIT IN THIS CONNECTOR THAN THE TJ. CUT THE UNUSED WIRE CLOSE TO THE CONNECTOR ON TJ MODELS.
Stagger cut the main harness and patch harness wires so that the solder joints will be 1/2 inch apart. Remove 1/2 inch of insulation from the wires. The new harness will have a dark blue with no tracer. This will mate with a dark blue wire with a green tracer on TJ and with a dark blue wire with a white tracer on XJ.
Slide a piece of heat shrink tubing over the wires and twist the wires together for each respective circuit.
Solder each circuit using rosin core solder. Be sure to heat the wire enough to allow the solder to melt when it comes in contact with wire. Do not use acid core solder.
Position the heat shrink tubing over the solder joints and shrink the tubing using a heat gun.
Install the connector to the bracket.
Install the instrument cluster.
Connect the battery cable.
Verify correct operation of the cluster.
POLICY:
Reimbursable within the provisions of the warranty.
TIME ALLOWANCE:
Labor Op. No.Time08-90-90-910.6 Hrs.
FAILURE CODE:
CodeDescriptionP8New Part
marc1kim is offline
post #6 of 7 Old 07-21-2007, 12:37 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
I've wasted my time removing the panel and checking the connection 3 times this year.Now I know to just bang the panel because the connection is a little loose.
TheBoogieman is offline
post #7 of 7 Old 07-22-2007, 09:55 PM Thread Starter
spendit66
I took the cluster out the connections seemed fine, I put it back together and it worked for one day then went again. Did the same thing now doesn't work. There is a code message on the odomitor it says "no bus" does that maybe mean something else
nothing on my dash cluster works?? Jackson21 TJ Wrangler Technical Forum 9 06-03-2009 02:22 AM
Dash Cluster Jeep25 TJ Wrangler Technical Forum 3 01-02-2009 11:09 AM
Dash cluster bulbs romanella YJ Wrangler Technical Forum 2 08-10-2007 12:51 PM
Dash cluster power? jeep973 TJ Wrangler Technical Forum 7 02-24-2007 02:57 PM
dash cluster lighting/bulb Q's el guapo YJ Wrangler Technical Forum 6 11-09-2004 09:49 PM
