Quantcast Dash cluster power? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Dash cluster power?
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Old 12-02-2006, 08:59 AM   #1
jeep973
Dash cluster power?
Last night I stopped to fill up with gas. When I got back in the Jeep and started it, I had no gauges. The lights on the dash work, but there is no tach. speedo, oil, gas. The odometer is also black. ANY IDEAS ON WHAT HAPPENED.
Is it a possible short somewhere? I have noticed that my intermitten wipers are not working anymore. The wipers also won't return "home" when they are shut off, they stop where they are. Can this be a cause?
jeep973 is offline   Reply With Quote
Old 12-02-2006, 09:18 AM   #2
Rocky529
Jeep
Rocky529's Avatar
Remove the cluster and clean the connections and apply dielectric grease.
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline   Reply With Quote
Old 12-02-2006, 09:23 AM   #3
yell2000
Common thing... freaked me out when it first happened.
Just pull the cluster and lightly rub/move the tabs in the connector without bending them.
Did it to mine once and the problem has not come back in almost 2 years.
2008 JK Unlimited Rubicon
1978 CJ-5
2000 TJ Sport 4.0
2002 KJ Limited
Now that I have the garage... gotta fill it!
yell2000 is offline   Reply With Quote
Old 12-02-2006, 10:03 AM   #4
daveg13
http://www.jeepforum.com/forum/f9/fix-your-tjs-dead-gauges-write-up-179282/
daveg13 is offline   Reply With Quote
Old 12-02-2006, 10:44 AM   #5
jeep973
Great info, thanks for the help, I'm headed out to work on it now.
Old 12-02-2006, 12:05 PM   #6
2fastlx
i just pounded the top of the dash with my fist, haven't had it happen since. If it happens again I'll take it apart and fix it right.
[CENTER][COLOR="Green"]Colorado Jeep Club Member #44[/COLOR][/CENTER]
[QUOTE]I couldn't really understand what you were saying or asking, but I think you need a bigger hammer.[/QUOTE]
2fastlx is offline   Reply With Quote
Old 02-24-2007, 02:02 PM   #7
milford623
i had the same problem wiht my 99TJ...did it intermidently and then no power to gauges all togetther.....i read the posts and chose the lazy route and just tapped on dash above gauges 2 times....everything works...im sure it is a bandaid however im too busy to take apart and clean...Thanks
milford623 is offline   Reply With Quote
Old 02-24-2007, 02:57 PM   #8
RangerDoug
It's a common problem. I've always used the pound the dash technique over the past few years but since I just removed the instrument cluster to install LED's in place of the the bulbs, I took time to tweak the connections a bit.
RangerDoug is offline   Reply With Quote
Glock Forum
