Dash Cluster Makover... Here's the Pics.
| Ruffstuff Axle Simple Swap Kit! | RUBICON EXPRESS Lift Kits and Accessories Available at Bas | Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line |
#1 | |
I purchased the tri-led bulbs and the blue incandescant bulbs. Here's the pics of what they look like.
What the bulbs look like: ![]() original bulbs: ![]() Blue Incandescant: ![]() Blue Led: ![]() Carbon Fiber Back: ![]() Carbon Fiber lit up: ![]() The blue incandescant bulbs were really dim compared to the LED's. The tri-LED bulbs seem to remedy the problem of the light not being evenly thrown throughout the cluster. I like the LED's the best. Also... The dimmer works perfectly w/ the LED's. I was asked to update this thread with the following information: Application for 2005 unlimited dash cluster six bulbs: size: #74 hvac three bulbs: size: T4 lower buttons (over drive, defog, ect) two bulbs per switch: size: one t3 and one t4 Shifter light (auto) one blub: size: 168 courtyse light two bulbs: size: 906 (search v-led its the same as 921) dome lights (two round light sound bar) Just get the high power universal kit. Its wicked bright two bulbs size: 211
#2 |
Wow...Thats some nice work you did. Looks great. Love to see how you wired the LEDS up and where you placed them. Did you just drop them in the stock bulbs' position?
[SIZE="1"][B]2005 Black Rubicon[/B] 4.0L I6 | 6spd Manual |33" BFGoodrich Mud-Terrains | SJ 4" Doubleflex | Warn Front & Rear Bumpers | Warn Tire Carrier[/SIZE] |
#3 |
Yep... stock locations in the stock bulb sockets.
#4 |
The outcome looks very nice. I thought about doing this a while ago, but wasn't sure what it looks like next to the green light in the center console.
Where did you get the carbon thing for the cluster face..?
olli '03 Rubi Just cuz you got the power, that don't mean you got the right! |
#5 |
where did u get the bulbs and what part numbers were they?
'00 TJ '63 CJ 5 |
#6 |
Mileage light?
What color does the mileage display in? Looks good.
What do you need to remove to get at the bulbs? |
#7 | |||
'00 Wrangler Sport | '10 Patriot Latitude | '04 Liberty Limited
#8 |
this looks like a great little upgrade. little more info one what kind of bulbs ya used! to do the whole dash and center (HVAC controls) would be pretty sweet.
keep the info comin! you didn't have to use resistors or anything else like that?
Formally JeepinTJ99 ... Go Anywhere: 2012 "Crush" Clearcoat JK Rubicon, loaded to the hilt || Thread Carve Time: 2009 "Racing Red" Buell 1125CR — 150 RWHP Will be missed: 1999 "Deep Amethyst" Pearlcoat TJ +3" on 33's |
#9 |
I'd like to do this with red LEDs.
Matt 2001 Jeep Wrangler Sport 4.0L - Amber Fire Pearl Coat 1981 DeLorean DMC-12 VIN: 2953 |
#10 | |
This looks too simple and I've seen it on the forums too many times recently not to give it a try. |
#11 |
#12 | |
#13 |
Zew, how long did it take you to switch the bulbs out? How do you get at the sockets?
#14 | |
The install is pretty easy. Its just a a few screw to take out the cluster 8 if I remember correctly. 4 for the dash and 4 for the cluster. The sockets for the bulbs just twist out of the back of the cluster.
#15 |
I'm still trying to figure out the bulbs. I thought it was the T1.5. But the replacement bulbs are either those or the 194.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
