Dash Cluster Makover... Here's the Pics. - JeepForum.com
post #1 of 578 Old 02-04-2007, 03:49 AM Thread Starter
Zew
Zew's Avatar
I purchased the tri-led bulbs and the blue incandescant bulbs. Here's the pics of what they look like.
What the bulbs look like:
original bulbs:
Blue Incandescant:
Blue Led:
Carbon Fiber Back:
Carbon Fiber lit up:
The blue incandescant bulbs were really dim compared to the LED's. The tri-LED bulbs seem to remedy the problem of the light not being evenly thrown throughout the cluster. I like the LED's the best. Also... The dimmer works perfectly w/ the LED's.
I was asked to update this thread with the following information:
Application for 2005 unlimited
dash cluster
six bulbs:
hvac
three bulbs:
lower buttons (over drive, defog, ect)
two bulbs per switch:
size: one t3 and one t4
Shifter light (auto)
one blub:
courtyse light
two bulbs:
size: 906 (search v-led its the same as 921)
dome lights (two round light sound bar) Just get the high power universal kit. Its wicked bright
two bulbs
Zew is offline
post #2 of 578 Old 02-04-2007, 03:52 AM
SuperBTZ
Wow...Thats some nice work you did. Looks great. Love to see how you wired the LEDS up and where you placed them. Did you just drop them in the stock bulbs' position?
2005 Black Rubicon
4.0L I6 | 6spd Manual |33" BFGoodrich Mud-Terrains | SJ 4" Doubleflex | Warn Front & Rear Bumpers | Warn Tire Carrier
SuperBTZ is offline
post #3 of 578 Old 02-04-2007, 03:54 AM Thread Starter
Zew
Zew's Avatar
Yep... stock locations in the stock bulb sockets.
Zew is offline
post #4 of 578 Old 02-04-2007, 04:05 AM
Saubaer
Saubaer's Avatar
The outcome looks very nice. I thought about doing this a while ago, but wasn't sure what it looks like next to the green light in the center console.
Where did you get the carbon thing for the cluster face..?
olli
'03 Rubi
Just cuz you got the power, that don't mean you got the right!
Saubaer is online now
post #5 of 578 Old 02-04-2007, 04:53 AM
traab007
where did u get the bulbs and what part numbers were they?
'00 TJ
'63 CJ 5
traab007 is offline
post #6 of 578 Old 02-04-2007, 05:41 AM
jdvailco
Mileage light?
What color does the mileage display in? Looks good.
What do you need to remove to get at the bulbs?
jdvailco is offline
post #7 of 578 Old 02-04-2007, 06:18 AM
Scott00TJ
I wondered the same thing. There are ones that look like yours on EBay?
x2
The mileage would stay the same OEM green since the LCD display is build into the cluster and not lit by bulbs like the rest of the cluster.
Scott00TJ is offline
post #8 of 578 Old 02-04-2007, 07:59 AM
C2U5H
C2U5H's Avatar
this looks like a great little upgrade. little more info one what kind of bulbs ya used! to do the whole dash and center (HVAC controls) would be pretty sweet.
keep the info comin! you didn't have to use resistors or anything else like that?
2012 Crush JK Rubicon on 2.5" and 37s
- see sidebar
C2U5H is offline
post #9 of 578 Old 02-04-2007, 08:03 AM
Conundrum
Conundrum's Avatar
I'd like to do this with red LEDs.
Matt
2001 Jeep Wrangler Sport 4.0L - Amber Fire Pearl Coat
1981 DeLorean DMC-12 VIN: 2953
Conundrum is offline
post #10 of 578 Old 02-04-2007, 08:08 AM
akjason
x100
This looks too simple and I've seen it on the forums too many times recently not to give it a try.
akjason is offline
post #11 of 578 Old 02-04-2007, 08:19 AM
Conundrum
Conundrum's Avatar
http://www.superbrightleds.com
Matt
post #12 of 578 Old 02-04-2007, 08:43 AM
Scott00TJ
Originally Posted by conundrum1984
Which ones?
post #13 of 578 Old 02-04-2007, 08:54 AM
KRV
Zew, how long did it take you to switch the bulbs out? How do you get at the sockets?
KRV is offline
post #14 of 578 Old 02-04-2007, 09:01 AM
Scott00TJ
I've done the standard bulbs in my TJ before. They just wern't bright enough so I went back to stock. I think I want to try the LED units after seeing Zew's post.
The install is pretty easy. Its just a a few screw to take out the cluster 8 if I remember correctly. 4 for the dash and 4 for the cluster. The sockets for the bulbs just twist out of the back of the cluster.
post #15 of 578 Old 02-04-2007, 09:04 AM
Conundrum
Conundrum's Avatar
I'm still trying to figure out the bulbs. I thought it was the T1.5. But the replacement bulbs are either those or the 194.
Matt
nothing on my dash cluster works?? Jackson21 TJ Wrangler Technical Forum 9 06-03-2009 01:22 AM
Dash Cluster Jeep25 TJ Wrangler Technical Forum 3 01-02-2009 10:09 AM
Dash cluster bulbs romanella YJ Wrangler Technical Forum 2 08-10-2007 11:51 AM
Dash cluster problems spendit66 TJ Wrangler Technical Forum 6 07-22-2007 08:55 PM
Dash cluster power? jeep973 TJ Wrangler Technical Forum 7 02-24-2007 01:57 PM
