Dash brake light blinking and beeping - JeepForum.com
post #1 of 6 Old 07-11-2006, 03:36 PM Thread Starter
CptTrips
So I was driving today and on a slight downward hill, I was stopped at a light, applying the amount of pressure I normally would for such a decline, when I feel myself rolling forward. I jam the brake in all the way and I stop, but my brake dash light comes on and the dash beeps like when I leave my lights on after I shut the engine off. The light then flashes a few times.
Anyone know what this means? Do I need to change my brake fluid, check the brake pads? Never had this problem before. Thanks.
CptTrips is offline
post #2 of 6 Old 07-11-2006, 04:23 PM
Red_
2016 KL Cherokee
Probably low on brake fluid
Red_ is offline
post #3 of 6 Old 07-11-2006, 04:51 PM
kadmos
which means you should still check for leaks, although it was probably just caused by the momentum (slosh), better safe than sorry though.
kadmos is offline
post #4 of 6 Old 07-11-2006, 05:06 PM
Rocky529
Rocky529's Avatar
Definitely low on fluid. Follow all your lines and look for the leak or you're going to be going head first into something you don't want to be heading head first into.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #5 of 6 Old 07-18-2006, 02:16 PM Thread Starter
CptTrips
I checked the fluid and brake pads... Everything looked to be in order.. So I fiddled with the cable that runs to my parking brake... And then that seemed to fix it. Few days later though, brake light is back on and beeping, and no amount of fiddling has done it. I'm pretty stumped..
CptTrips is offline
post #6 of 6 Old 07-18-2006, 02:36 PM
Jeepin' Rock Cl
The brake light comes on when 1) low on brake fluid or 2)ebrake lever is lifted. If you're not low on fluid, then it's the ebrake lever switch.
Jeepin' Rock Cl is offline
Blinking rear lock light on dash in Rubicon sct11 TJ Wrangler Technical Forum 12 11-11-2009 07:22 AM
Blinking brake light on dash hotnutz TJ Wrangler Technical Forum 2 03-12-2008 01:42 PM
my dash wont stop beeping losfreddy TJ Wrangler Technical Forum 4 10-08-2007 08:21 PM
Blinking Light on Dash That Says "Brake" Capinsano3 TJ Wrangler Technical Forum 16 10-13-2006 10:11 PM
Dash Brake Light JeepDrivr93 YJ Wrangler Technical Forum 4 11-13-2004 10:48 PM
