Dash Board Light Not Working after New Stereo Install - JeepForum.com
post #1 of 7 Old 01-13-2011, 06:41 PM Thread Starter
higgins192
Hey Forum,
i just installed a Alpine head unit into my 99' TJ. well i bought this form Crutchfield so it came with the wire harness well the instillation went ok but as i was pushing the head unit in and my dash lights turned out but everything like the guages work except the lights. ive check the fuses and none are still blown. can you please help me?
higgins192 is offline
post #2 of 7 Old 01-14-2011, 08:14 AM
Noxian
2011 JK Wrangler
maybe grounding your illumination wire?
I would pull the deck and check for any pinched or cut wires, could have got caught when you pushed the deck in.
Noxian is offline
post #3 of 7 Old 01-14-2011, 08:41 AM
seadoons
There are a couple of wires that are not used. There is an illumination wire that provided power to the lights in your factory radio and there is also a dimmer wire that would dim said lights. Both are not used with an aftermarket stereo and need to be taped off so that they do not ground out against something back there. Pull your aftermarket radio back out. Any wires that are unused on the harness need to have electical tape wrapped around the end so that no piece of bare wire is exposed. Reinstall and then find the fuse that you blew. I am 98% confident you blew a fuse.
seadoons is offline
post #4 of 7 Old 01-14-2011, 10:21 AM
cvisinho
check above but pull the deck out and check to see if any other harnesses were made loose back there while stuffing wires in the back.
cvisinho is offline
post #5 of 7 Old 01-14-2011, 10:33 AM
jeepmudgirl
I had the same problem. The person who installed it tapped into my dash light wire as the ground. Kept blowing the fuse and I didn't have any dash lights or tail lights.
All Girl Jeep Club Member #4
White Jeep Club Member #24
2012 Jeep Wrangler Unlimited Sport - Stock..for now
2000 Jeep Wrangler Sport - 4" lift with 33's
8.8, AtoZ rocker guards,Rockhard cage add on....etc.
jeepmudgirl is offline
post #6 of 7 Old 01-15-2011, 10:33 PM Thread Starter
higgins192
yeah after yakeing my whole dash apart i called Crutchfield and go figure it was the fuse i didnt see/check which was #3 behind the glove box labeled "pannel Lights". needless to say i felt stupid. but the orange and white wire grounded out blowing the fuse. so after reassembeling my dash and clipping the orange and white wire and a trip to Walmart later for my 10A fuse it was back working again.. thank you all for your help and Merphy's Law got me good
post #7 of 7 Old 08-06-2013, 07:09 PM
kermithood
murphy's
kermithood is offline
instrument cluster , lights , not working , stereo system
Clicking in the dash/ Stereo isn't working PhillyAIDCop TJ Wrangler Technical Forum 0 08-05-2009 11:25 PM
Stereo Stopped working after installing a new dome light RedlineRyan YJ Wrangler Technical Forum 4 01-26-2009 08:26 AM
dash light not working haxsaw YJ Wrangler Technical Forum 9 03-05-2007 05:30 PM
4WD dash light not working MyRig is Yellow TJ Wrangler Technical Forum 2 04-09-2006 10:26 AM
dash light are not working samizx7 YJ Wrangler Technical Forum 5 02-16-2005 10:02 PM
