dana 44a vs dana 44 - JeepForum.com
post #1 of 4 Old 05-13-2008, 06:19 PM Thread Starter
airframer
airframer's Avatar
dana 44a vs dana 44
so the difference between the dana 44 and the dana 44a is the fact that the 44a has an aluminum casing?? is that the only difference and r both 30 spline?
Everything in moderation
airframer is offline
post #2 of 4 Old 05-13-2008, 06:23 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
They're different internally too. Lockers for the cast iron Dana 44 will not fit in the Dana 44a's aluminum housing. Plus the D44a is a c-clip design, not very desireable.
Getting
Jerry Bransford is online now
post #3 of 4 Old 02-25-2014, 06:35 AM
moose27
Now I know that the 2 axles are different and I've done my homework on this some what but couldn't I take a skid plate made for a regular d44 and mod it so that I can make it work on a 44hd? I'm guessing since it's not dealing with a new diff cover and dealing with all the inside components I could make this plosible right?
Build: http://www.jeepforum.com/forum/f13/mooses-jeep-build-1456174/
moose27 is offline
post #4 of 4 Old 02-25-2014, 02:33 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Sure, I suppose you could make it work. Anything can be made to work with a welder, torches, and cutting wheels.
How difficult it will be to fit to the D44a will depend on how the skid attaches to the D44.
Wheelin98TJ is offline
aftermarket front dana 44 vs. built dana 30 bigwyrm TJ Wrangler Technical Forum 9 04-04-2011 01:02 PM
my dana 35 snaped again can i swap the parts out of a 1990 dana 35 from a cherokee bulickmcj TJ Wrangler Technical Forum 7 04-02-2009 12:42 PM
Dana 35 drum brakes transfer to Dana 44? greendot200200 TJ Wrangler Technical Forum 4 01-21-2009 11:12 PM
Build Thread for my Dana 44 and Dana 60 axles... Pics & Questions Inside Big-n-Broke-YJ YJ Wrangler Technical Forum 9 07-11-2006 09:37 AM
QUESTION: front axle(DANA 30) why does mine look like a DANA 35 713JeepTJ TJ Wrangler Technical Forum 5 03-06-2005 09:20 PM
