#1 | |
2003x
Dana 44 VS. C Clip Eliminator?
Hi,
I currently run a D35 with 3.07 Gears, My question is, I can get a used Dana 44 out of a junk yard for $1000. Currently on 4x4groupbuy, I can get a c-clip eliminator for $579..... Superior Axle M35 Super Eliminator C-Clip Eliminator Kit 90-06 Y Is this the kit that will fit my 2003 TJ? Will it make my axle stronger to wheel and run 35s later on? Other websites are offering this kit for $800+, and for another $200 I can get the super 35 kit with a locker for the same price as the used Dana 44. Any advice will be helpful, thanks in advance. 2003X
Big Axles and Big Tires! My Build http://www.jeepforum.com/forum/f22/2003x-tj-build-944608/ |
#2 |
you need this part number cause you have 27splines 4x4GroupBuy.com eyou'll need a 30spline carrier or locker.
#3 |
the 30 spline chromos with the c-clip eliminator will make it stronger than a stock 44. however people will argue that the d44 R&P is alot stronger but the difference between the two is pretty small. i run a S35 with 35" tires without the c-clip eliminator and have never had a problem with it. in the future id like to get it though
also 1000 for a junkyard 44 seems like alot. a buddy of mine just picked one up that was already built with a locker for 1000
Photographer at heart Have questions about something photography related? Click here!Like Coheed and Cambria? Join the club! My Jeep Build My Photography (New as of Jan. 25th) 1982 Motorcycle Build |
#4 |
2003x
I figured $1000 was alot as well. I dont no what they go for used.
I would like to run the c-clip eliminator kit, Is this the correct kit with 27 spline... Superior Axle M35 Super Eliminator C-Clip Eliminator Kit 90-06 Y ? Does this price $580 seem reasonable for a C-Clip Eliminator?
#5 |
no whiners!
When you say 1000 for a D44 are you talking about a TJ d44 or one out of a different vehicle> Because if it is for a TJ then you should jump on it. Tj 44's with 3.73 gears and trash lock go for almost 2 grand at JY around here. Believe me I have checked.
#6 |
I am a firm believer that a d-35 with upgraded axles & c clip eliminator is a very good choice but the 307 gearing is got to go.Saying that the d-44 is almost guaranteed at least 373s.D-35 Axles + c-clip + gears+ labor = more then the d-44.The d-35 to d-44 is an easyer job to swap out then to regear & install the axles & c -clip elim.Regearing is not a simple job done yourself unless you know what your doing.
#7 |
2003x
This is what the place says.. Its out of a 2003 Jeep Wrangler TJ, Spcr 44, LHD, 3.73 ratio, Rr drms Complete Assembly.
#8 |
your on 33's now and going to 35's?
Super 35 kit with or without c-clip eliminators. 4.56 or 4.88 gears, 4.88 preferred for 35's. You'll need to do the front too. Spending 1K for a 44 and then having to regear it and add a locker =$2500
Get Savvy |
#9 | |
no whiners!
I also think the C-clip eliminator is a fine idea. Some run them just fine. Others have had problems. There are monster threads about these kits. I considered one for a while. Good luck with your decision. Last edited by theducksguts; 09-17-2009 at 04:09 PM.. Reason: I don't know that |
#10 |
2003x
Eventually I will be going to 35s, but not any time soon.
so still I am unsure the path to take on this, $1000 for a used rear D44, or $600 for superior super eliminator C-Clip Kit? I would have to re-gear the D44 and D30 to the correct gears, and now im into more money. Maybe the C Clip Kit is fine for now, then re-gear my D35 with the c-clip later on? I have read multiple threads on here, and it seem 50/50. Some say go with the D44, and other says the C-Clip is just as strong as a stock D44. Is the c-clip kit the same as the super 35 kit, just without the locker? Is this the correct kit with 27 spline for my D35.... Superior Axle M35 Super Eliminator C-Clip Eliminator Kit 90-06 Y ? Sorry for all the questions, I just want to do it right the first time.
Big Axles and Big Tires! My Build http://www.jeepforum.com/forum/f22/2003x-tj-build-944608/ Last edited by 2003X; 09-17-2009 at 04:20 PM.. |
#12 |
I found a D-44 from a 06 tj for 850 bucks installed and gave him the D-35 witch was good for me because I had no place to store the 35.I could have done it my self(did my share) but what the hell I did not have to get my hands dirty.
#13 | |
no whiners!
With the C-Clip eliminator it comes with 27spline moly shafts and the retainer hardware that has to be mounted at the drums. There is no locker and they shafts still have the same spline count. They just don't utilize the C-clips. Still wouldn't want to drive any distance on a broken axle. Not safe. |
#14 | |
Ring Gear Diameters - Dana 35c = 7.562" Dana 44 = 8.5" Dana 60 = 9.75" Dana 70 = 10.5" Dana 80 = 11.25" Source: http://www.precisiongear.com/ The jump from Dana 35 to Dana 44 is almost the same as the jump from Dana 44 to Dana 60, and from Dana 60 to Dana 70. 1" is not small when talking about ring gear diameter as it correlates to strength. Go for the Dana 44, don't not sink money into the turd of a D35.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
