Dana 44 v. Built Dana 30 - Page 2 - JeepForum.com
post #16 of 22 Old 11-16-2013, 06:13 AM
offroad349
I gotta upgrade the profile, did an inline6 swap haha
offroad349 is offline
post #17 of 22 Old 11-16-2013, 07:14 AM
Iceman_RNR
it pops up every so often, but 37s on a TJ is the breaking point (literally), regardless of (HP)Dana30 or Dana44 and strengthened axles or not.
OP: what's the upside of running 37s instead of 35s for you at this point? It takes money to make that step ...
'84 CJ7, '96 CTD, '00 TJ
Iceman_RNR is offline
post #18 of 22 Old 11-16-2013, 07:58 AM Thread Starter
Jeepin72
Look at my original post. This thread is from 2010.
For the record, I am have a 14 bolt rear and 60 front to turn 40"s.
Jeepin72 is offline
post #19 of 22 Old 11-16-2013, 10:49 AM
Iceman_RNR
that's something I completely missed
The exception to the rule dug up this old thread ... and whatever 'wheel the HELL outta my jeep' means ...
Originally Posted by offroad349 View Post
I have a 2000 TJ running 37's on a stock D30, 4.88 gears, inner C Gussets, stock shafts, and I wheel the HELL outta my jeep with no problem. I have a buddy who runs 40's on a 2014 JK STOCK D30 with no problems....its all in how you drive. Good Luck!!
post #20 of 22 Old 11-16-2013, 02:08 PM Thread Starter
Jeepin72
Yeah no worries. I was a bit surprised when I saw this one resurface. It has some valid discussion points.
IMO
1) A D30 just won't hand 37's with the terrain I am used to.
2) I've seen JK 44's handle 37's with a lot of work done to them.
3) Going from 35 to 37 wasn't going to be worth it unless I spent a pile of money on crate axles.
4) The junkyard route for one tons was far easier to turn large meats
Heck, I blew up a D60 short side shaft on the first slick rock trail I was on. Anything can break, some just less than others!
Jeepin72 is offline
post #21 of 22 Old 11-16-2013, 02:11 PM
Ironhead
what about a rubi 44 rear with arb and alloys? i know the fronts weaknesses, but it seems like the only thing holding the rear rubi44 back is the lsd carrier
Ironhead is offline
post #22 of 22 Old 11-16-2013, 02:33 PM Thread Starter
Jeepin72
From what I recall it does make a difference if it is a TJ or JK rear 44. I had a TJ rear 44. Different spline count than the JK. From the factory it is a 30 IIRC and can be upgraded to a 35 spline. I think the JK was 32 or 33 from the factory and was larger. The front 44 in the JK has a larger ring gear than the D30. It is more amenable to being built up with chromos and gussets and handling 37's.
I had a 35 spline carrier and and alloy shafts in my rear 44 when I had it. It handled the 35's with no issue at all. It may have handled 37's. I know someone running 37's on TJ rubi axles and has not problems yet.
It was when I wanted to go bigger that it became the problem. At the time I could fit 37's without anymore stretch, lift, and sheet metal being cut. The cost to get a matching front was the problem. After doing some figuring and predicting an end goal I ended up in a larger direction.
After considering crate axles, JK junkyards, truck D44's, and many other options... I went with a 60/60 combo. That didn't last the summer as the 30 spline rear 60 twisted a chromo on the first day out.
I ended up slinging in a 14 bolt mid summer. So far so happy.
I need to go back and do a 35 stub conversion on the front 60, but all is time and money.
Jeepin72 is offline
37s , dana 30 , dana 44
Will a dana 35 brum brake backing plate swap onto a dana 44? wzrroc TJ Wrangler Technical Forum 4 03-08-2014 08:24 PM
aftermarket front dana 44 vs. built dana 30 bigwyrm TJ Wrangler Technical Forum 9 04-04-2011 12:02 PM
Built Dana 44 vs. Super 35 bstew417 TJ Wrangler Technical Forum 100 06-08-2010 10:42 PM
Dynatrac Next Gen JK dana 44 built for TJ gcally TJ Wrangler Technical Forum 10 10-14-2009 02:30 PM
Build Thread for my Dana 44 and Dana 60 axles... Pics & Questions Inside Big-n-Broke-YJ YJ Wrangler Technical Forum 9 07-11-2006 08:37 AM
