Dana 44 spider gears: same in open and ls carriers? - JeepForum.com
post #1 of 3 Old 07-15-2010, 04:28 PM Thread Starter
cheapfix
1991 XJ Cherokee
Been searching, looking up the spider kit on a couple of online retail sites, and can't find a different set of parts for the open-carrier vs. trac-loc D44 spider and sidegear set. Anyone know if they are the same?
Found this in the rear diff of my (new to me) 01 TJ w/ D44/ls:
I have an old set of spiders from my aussie install in my XJ d44 -- should I just swap those in? Go new? Opinions?
Got lucky as there is no major damage to the r&p -- very small nick on one tooth of the ring. The chunks that came off the spiders were small enough to mind their own business at the bottom of the pumpkin I guess...
Thanks!
Recovering moparholic
cheapfix is offline
post #2 of 3 Old 07-15-2010, 04:30 PM
LKrux
if theyre the same, id just swap in the spider gears that you have laying around
4.0, 5sp, bfg33's, 3 1/2 lift
LKrux is offline
post #3 of 3 Old 07-15-2010, 09:45 PM Thread Starter
cheapfix
1991 XJ Cherokee
Yeah, thanks. I will pull the broken ones out and compare them. Might re-use the old ones I have. I will have to buy some parts though-- looks like the spring/thrust washer/ whatever that sits under the drivers side sidegear is busted too -- this may have started the whole thing with chunks of it jamming in the sidegears.
cheapfix is offline
d44 , dana 44 , limited slip , open , open carrier , open diff , spider gear , spider gears
any dana 35 spider gears? legend6009 TJ Wrangler Technical Forum 6 04-05-2008 12:05 PM
are all dana 35 spider gears the same? broke99tj TJ Wrangler Technical Forum 5 11-26-2007 07:14 AM
dana 35 spider gears 1.56 vs 1.62 subzeroedj TJ Wrangler Technical Forum 2 08-08-2007 07:56 PM
Are Dana 35 spider gears the same? JOKER4INK YJ Wrangler Technical Forum 7 03-23-2007 06:03 AM
Can u put spider gears dana 30 with out resetting the gears? magnum629 TJ Wrangler Technical Forum 2 02-19-2007 10:55 AM
