Dana 44 regear - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Dana 44 regear
Nitro Gear Packages Now Available at Rockridge 4wdJEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFFThe ULTIMATE "Selectable" Locker System! Brough
Unread 11-25-2014, 09:12 PM   #1
Dmarkowski
Dana 44 regear
Hi all,
Suggestions on a rear end regear? 4.83 or 4.54 ? Have a 00 TJ 4.0 5 Speed with 33s. Looking to go 35s eventually. I do both highway and city driving. Can I just replace ring and pinion or do I have to jump into the carrier?
Dmarkowski is offline   Reply With Quote Quick reply to this message
Unread 11-25-2014, 09:25 PM   #2
NHfireLJ
Jeeper Creeper
NHfireLJ's Avatar
what gearing do you currently have? Many run 35's w 4.10 gearing on the 4.0 with no issues...
If are not aware.... Swapping gears isn't as easy as pulling out the old and installing new.... It requires careful set up... not saying it can't be done by a novice but really should be done by an experienced tech... Can cost anywhere from $500- $1000 depending on the shop...
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
BETTY...94 SE, Stroker 4.6, 4.5,lift,35"s,D30 Aussie, 8.8. Sold
Hummer Intake
http://www.jeepforum.com/forum/f12/h...style-1257285/
NHfireLJ is online now   Reply With Quote Quick reply to this message
Unread 11-25-2014, 09:27 PM   #3
NHfireLJ
Jeeper Creeper
NHfireLJ's Avatar
Originally Posted by Dmarkowski View Post
Hi all,
You are aware you need to re-gear BOTH axles if you do regear....?
Hummer Intake
Unread 11-29-2014, 09:41 AM   #4
TAS
I've got 4.0 and 5 spd and just regeared to 4.56. At first I had 35's and it was fine. I just installed 33's and it's fine. With 35's @ 65, I'm running around 2400 RPM (+/-) and with the 33's I'm around 2500 RPM (+/-). I'm running 15-16 mpg (75% hwy @ 65 mph) on both set-ups.
I came up from 3.73's, so I had to replace the carrier in the D44.
Todd
98, I6, 5spd, 4" Lift, 33's and a few other mods that get me there.
Tow rig - 12 F-350 4x4
TAS is offline   Reply With Quote Quick reply to this message
Unread 11-29-2014, 10:00 AM   #5
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
The D44 carrier break is 3.73/3.92.
Whether a carrier change is needed depends on what your current ratio is.
If you have the likely 3.73 ratio, you'll need the change carriers in order to gear to a deeper ratio (4.56, 4.88, etc.).
Or your other option is to keep your existing carrier and use a thick cut gear set.
Since you are planning on 35s, I think 4.88 is the right ratio for you.
Wheelin98TJ is offline   Reply With Quote Quick reply to this message
Unread 11-29-2014, 11:20 AM   #6
relgnarw
If you live in the mountains I'd go 4.56 or 4.88. You'll need a deeper gear for some of those grades.
"I had wobster at Wed Wobster" - Austin age 5
My onboard air build.
[url]http://www.jeepforum.com/forum/f176/viair-install-02-tj-w-cruise-5-spd-1379665/[/url]
relgnarw is offline   Reply With Quote Quick reply to this message
Unread 11-29-2014, 11:32 AM   #7
Hosejockey61
But why would you run 4:10 with that tire/tranny/motor combination? If you have to regear, do it right the first time. Throwing 4:10 out there doesn't even make sense. Even if the PO's current gearing is 4:10, I'd still set up both axles with 4:88 in anticipation of the 35's.
Hosejockey61 is online now   Reply With Quote Quick reply to this message
Unread 11-29-2014, 12:04 PM   #8
irnmadn88
He has a point.
I see a LOT of Jeeps dogging it coming up I-70 from Golden- big tires and no gears.
Colorado Jeep Club Member #667
irnmadn88 is online now   Reply With Quote Quick reply to this message
Unread 11-29-2014, 12:08 PM   #9
Jerry Bransford
Administrator
Jerry Bransford's Avatar
For 35's, go 4.88 which is an ideal ratio for that size tire and 5-speed transmission... ideal for both the highway and offroad. 4.56 isn't quite there. I've been "slightly" undergeared once when I ran 4.10 with 33's and I'll never make that mistake again.
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote Quick reply to this message
Unread 11-29-2014, 12:21 PM   #10
Dmarkowski
When we regear to 4.86. Can you replace just the ring and pinion gear for the front and rear end? Or is it not that simple. Some people are saying that there is more to it than that but don't elaborate at all
Unread 11-29-2014, 12:25 PM   #11
MrSmiley
Originally Posted by Wheelin98TJ
The D44 carrier break is 3.73/3.92. Whether a carrier change is needed depends on what your current ratio is. If you have the likely 3.73 ratio, you'll need the change carriers in order to gear to a deeper ratio (4.56, 4.88, etc.).
Certified Web Wheeler
MrSmiley is offline   Reply With Quote Quick reply to this message
Unread 11-29-2014, 12:25 PM   #12
Jerry Bransford
Administrator
Changing the ring & pinion gears is a lengthy demanding process that if not done perfectly, will ruin a new ring & pinion gearset in short order. There is a great deal of expertise in getting it done correctly so the new gears will last and run quietly. If you go into a 4x4 shop with 4 mechanics in the back, maybe one of them will be experienced enough to be able to do a ring & pinion installation correctly.
Getting Savvy...
Unread 11-29-2014, 04:01 PM   #13
NHfireLJ
Jeeper Creeper
NHfireLJ's Avatar
If he already had 4:10s (I originally thought he had a rubi) then he could run what he has... 4.10 with 4.0 and 5 spd is a fine combination (not the best but works).... works fine on my YJ and now on my LJ 6 spd however... Why drop $1500-2000 if you don't have too...
Obviously he doesn't have 4:10 so the point isn't valid...
Hummer Intake
Unread 11-29-2014, 04:13 PM   #14
Jerry Bransford
Administrator
I sure wouldn't agree that many run 4.10's with 35's and the 5-speed transmission with "no issue". Can it be done? Well, that depends on if you're happy with an inappropriate gear ratio that means more clutch slipping and poor performance when compared to having the right gearing for the tire size. My opinion is that if you can't afford to regear to the right axle ratio, you have no business installing 35's. 4.56? Maybe... that's at least debatable. But 4.10's with 35's when the transmission is the 5-speed, I sure wouldn't be telling anyone there would not be an issue running it.
Getting Savvy...
Unread 11-29-2014, 04:41 PM   #15
NHfireLJ
Jeeper Creeper
NHfireLJ's Avatar
I agree its not the optimal, can it be done till the $$ for regear is available yes... Beats buying tires twice... And on my YJ with the stroker the extra HP / torque it was fine...
Hummer Intake
