Dana 44 rear wheel bearing size - JeepForum.com
post #1 of 21 Old 08-12-2013, 10:56 AM Thread Starter
Breehill
I searched and could not find a definite answer. Im trying to replace both my rear wheel bearings (get this creaking noise) and as i said not sure what size to get and what parts. Its not leaking so i donít think i need a seal and can just get the bearings and retaining ring. I know you have to drill/pry the old ones off and get the new ones pressed
So my question is, Is this all i need to get? http://www.ringpinion.com/b2c/Produc...rce=DiffWizard
can you put a ling to a better/different one?
have a 2004 LJ with a dana 44
thank you
Breehill is offline
post #2 of 21 Old 08-12-2013, 12:56 PM
Stu Olson
Stu Olson's Avatar
Dana 44 uses a SET10 set.
Here is a write-up for changing out the D44 axle shaft bearing and seal.
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #3 of 21 Old 08-12-2013, 03:30 PM
Spyder05
Once you remove the seal you are asking for leaks. Spend the 5 bucks and get some seals. You will thank yourself later.
05 Tj d44's, 4.88's, ARB's, 37's and some bling
99 TJuggy tons, 40's
14 RAM 1500
07 SRT 8 grand
Spyder05 is offline
post #4 of 21 Old 08-13-2013, 07:11 AM
otisdog
2008 WK
otisdog is offline
post #5 of 21 Old 08-13-2013, 07:19 AM Thread Starter
Breehill
Thank you! appreciate all the help, from everyone!
Breehill is offline
post #6 of 21 Old 08-19-2013, 10:37 AM
JPcpa
Did you install new bearings and was this the problem? I've got the same diff and have a slow speed rear wheel creak, and my outer seal and axle tube is wet with diff fluid.
2004 LJ, Auto, Zone 3.5"/1.25"BL/MML/285 KO2s
2005 Rubicon
99 Sport
JPcpa is offline
post #7 of 21 Old 08-20-2013, 09:22 AM Thread Starter
Breehill
Hey, I just got the wheel bearings in today. I'm pulling the axel tomorrow night and getting them pressed and reinstalled Thursday morning so ill let you know Thursday night. If it still makes the noise im thinking the u-joint(which was also suggested)
Breehill is offline
post #8 of 21 Old 08-20-2013, 10:00 AM
JPcpa
Ok thanks, I'm wondering if mine isn't possibly the LSD as well. The creaking sounds like it could be the clutches binding when they shouldn't.
But since my bearing seal is leaking I need to inspect and replace them anyway was well.
2005 Rubicon
99 Sport
JPcpa is offline
post #9 of 21 Old 08-23-2013, 05:54 AM Thread Starter
Breehill
Update: Bearings wont be pressed until "maybe" today, but most likely tomorrow (saturday). The axle shafts came out very easy and only took 10 mins to remove both and another 40 to remove the old bearings (drill and chisel method)
Breehill is offline
post #10 of 21 Old 08-23-2013, 06:04 AM
Zeep
Do you know if this set includes the collar?
JEEP THE AR-15 OF THE AUTOMOTIVE WORLD
Zeep is offline
post #11 of 21 Old 08-23-2013, 06:11 AM Thread Starter
Breehill
the collar? if you mean the retaining ring then yes. it includes the bearings, a seal, and the retaining ring. That is what i bought
Breehill is offline
post #12 of 21 Old 08-23-2013, 10:14 AM
Zeep
Awesome, saved it to my favorites!
Zeep is offline
post #13 of 21 Old 08-23-2013, 10:51 AM
marka2k
2006 WK
Both sides on my rear are leaking, going to have to do this soon. Bookmarked as well. Thank you
Silver WK Club #46
06 WK Overland
04 Rubicon
2000 Grand Cherokee
2006 Commander Limited - Wife's
marka2k is offline
post #14 of 21 Old 08-24-2013, 01:30 PM Thread Starter
Breehill
Update #2: the shop that was supposed to press my bearings called and said they aren't supposed to be pressed on the shaft but hammered into the axle. Clearly they have no idea what there doing so I picked them up and am bringing them to another forum members garage Tuesday AM so official update will be Tuesday PM. Sorry for the delay. This is annoying
Breehill is offline
post #15 of 21 Old 09-03-2013, 04:15 PM Thread Starter
Breehill
Well it's not the wheel bearings. Replaced both rear bearings and still makes the noise. I will say not as loud or as often but it's defiantly still there. Guess U joints are next
Breehill is offline
