Dana 44 Rear Axle oil seep? - JeepForum.com
post #1 of 3 Old 07-18-2003, 11:08 AM Thread Starter
MotorRad
This is my 1st post on this forum. Lot of good info. Very similar to the TDR forum (for Cummins Diesel owners).
My question is for those with experience with the D44 rear axle.
The rear on our 03 Rubicon seems to have what appears to be oil wicking on the exterior ends of the rear D44 right where the axle tubes meet the backing plates. No drips, just oil wicking onto the rust patina of the axle tubes at those points.
Now I've removed the wheels and rear brake rotors, and the seals are not leaking. No evidence on the interior of either side; emergency brake shoes are fine. Jeep only has 2900 miles.
Axle is not over filled. A call to the service manager of our dealer resulted in "thats normal for those axles". Sounds kind of fishy to me, but I've no experience with the D44. This never happened on the D35C on our YJ, nor has it ever happend on the D80 on the Dodge. Anybody ever see something similar on their D44 equipped TJ's?
Tim
03 Rubicon stock (so far)
95 Cummins Ram 4x4, not close to stock
MotorRad is offline
post #2 of 3 Old 07-22-2003, 05:52 AM
twistedtj
I have a d44 in the rear of my 2000 sport that is doing the same thing. I can not say that it is normal, I just know that I am having the same problem. On the left side one of the axle seals blew out, and I took it to the dealer under warranty and had it repair, but the seepage is still there. Good luck with it.
twistedtj is offline
post #3 of 3 Old 07-22-2003, 06:21 AM
GenXSlkr
GenXSlkr's Avatar
Check this out, it is not a 44 itís the 30 front so it may be of no help. Your post does sound similar to the problem my front 30 had. If it is I posted what the dealer did to correct it at the bottom. I will take a look at my rear D44 to see if I see what you are describing.
Seepage post
Good luck
GenX
02 TJ sport, Teraflex 3", 33X12.5, 4.0, 5spd.,D30/D44 4:56 w/rear detroit
GenXSlkr is offline
dana 30 as rear axle? richchs62 YJ Wrangler Technical Forum 20 07-05-2013 07:29 PM
Anyone looking for a TJ Dana 44 rear axle? Wheelin98TJ Wrangler General Discussion 8 07-31-2008 08:38 AM
Does the rear diff seal always seep-leak? berjepalon YJ Wrangler Technical Forum 4 05-26-2006 10:45 AM
Dana M35 Rear Axle? map7711 YJ Wrangler Technical Forum 3 03-02-2006 01:45 PM
