Dana 44 rear axle locking and noise, caused by LSD? - JeepForum.com
post #1 of 2 Old 08-16-2009, 07:17 AM Thread Starter
OffroadRookie
I have an 6-cyl 2004 TJ Sahara automatic. Since about two months ago I've had problems with something in the rear axle.
First time problem occurred was while going through a roundabout, halfway through the 270 degree to turn left there was a loud metallic bang from the rear. But nothing more. After this I started noting that whenever I go slowly (2-3 mph, sometimes up to 10) and going slightly right or left there is a thudding noise coming at fixed intervals from the rear. I can also clearly feel what resembles the rear axle being locked and released then repeated, at same rhythm as the noise. Symptoms only occurs when turning while going slow.
I went to a local workshop to get a second opinion and they suggested the noise is caused by the the rear limited slip being worn out. And they also suggested that the loud initial bang was caused by the rear axle being completely locked for a short while during the turn through the roundabout. That turn was taken at 15mph+. They tried changing the oil in the rear differential but it didn't help, so in this case the only thing that would help would be a change of the clutch pack. But since they would be charging a ridiculous amount to do this I'd like to get another opinion regarding this.
Does the LSD (Trac-loc) wear out in such way that it locks the rear axle? Could the noise be caused by something else? Bearings? Is it possible to simply remove the LSD functionality and use the rear diff as the regular open diff?
Jeep has primarily been used as DD and on 12-15 occasions for some 3-4 hour long dune bashing trips.
OffroadRookie is offline
post #2 of 2 Old 08-16-2009, 08:50 AM
Pillswoj
Yes the Trac-loc wears out, however it just stops working and acts like open when this happens. You have something wrong with the carrier, it could be the clutch packs, could also be the spider gears or the side gears.
Did they pull the cover and inspect it when they changed the fluid or just pump out the old and put in new? If they did not pull the cover then that would be the first step - you may have a broken piece of clutch in there causing more damage as time goes by.
Friends don't let Friends run Bosch
Pillswoj is offline
2" Coil Spacers caused u-joint noise? netwurk TJ Wrangler Technical Forum 4 12-17-2009 04:06 PM
Bad front axle seal. Ideas of what caused it? mschviuz TJ Wrangler Technical Forum 3 10-18-2008 03:26 AM
Do I have locking rear axle??? 99dime YJ Wrangler Technical Forum 3 11-25-2006 10:10 AM
Front Axle hop caused by shocks to soft? 97TJGUZZY TJ Wrangler Technical Forum 3 07-18-2005 01:05 PM
does 35 rear axle have locking diff/limited slip johnnyclaytkp YJ Wrangler Technical Forum 9 11-23-2004 04:57 PM
