Dana 44 Pinion Oil Seal Replacement??? - JeepForum.com
post #1 of 4 Old 08-22-2005, 08:45 PM Thread Starter
pbungar
I just removed the leaking rear pinion oil seal on my 99 TJ's Dana 44. Now I am ready to install the new one but am wondering what the torque spec. is on the pinion yoke nut (it was tigher that $&%! getting it off!). I don't completely understand the Haynes manual's explanation of 5 in-lbs past the torque required to turn the wheels (jacked up) when the original assembly was together minus the driveshaft.
99 Red TJ, I6, D44 rear, 1" M.O.R.E. BL, 1" M.O.R.E MML, 2" RE BB, 32" BFG MT's, 15x8 Procomp 1060's, APN Exhaust Header
pbungar is offline
post #2 of 4 Old 08-22-2005, 09:36 PM
otisdog
2008 WK
Well if you didn't measure the in. lb. torque before you took the pinion nut off it's too late now anyway. My FSM shows 160-200 ft. lbs.
Jim
08 Grand Cherokee Overland
otisdog is offline
post #3 of 4 Old 08-22-2005, 09:41 PM
AjRagno
It should be around 160 ft. lbs. Techinically, you should have measured it before removing the nut.
-Install yoke on pinion gear with Installer W-162-D, Cup 8109 and Wrench 6958 (Fig. 32). CAUTION: Do not exceed the minimum tightening torque 217 Nm (160 ft. lbs.) when installing the pinion yoke retaining nut at this point. Damage to the pinion bearings may result.
-Install pinion washer and a new nut on the pinion gear and tighten the nut until there is zero bearing end-play.
-Tighten pinion nut to 217 Nm (160 ft. lbs.) .
-Rotate pinion gear a minimum of ten times and verify pinion rotates smoothly.
-Rotate pinion shaft an inch pound torque wrench. Rotating torque should be equal to recorded reading plus an additional 0.56 Nm (5 inch lbs.) (Fig. 33).
-If the rotating torque is low, use Spanner Wrench 6958 to hold the pinion yoke, and tighten the pinion nut in 6.8 Nm (5 ft. lbs.) increments until the proper rotating torque is achieved.
-Install propeller shaft with reference marks aligned.
-Add gear lubricant to the differential if necessary.
AjRagno is offline
post #4 of 4 Old 08-23-2005, 09:27 AM Thread Starter
pbungar
I did measure the torque required to turn the wheels freely with the original nut in place and it was ~160 in-lbs. So if I understand this correctly, I am supposed to torque the nut (160-220 ft-lbs) until it requires approximately 165 in-lbs to turn the wheels freely?
pbungar is offline
Dana 35 Pinion Seal replacement question 95wrangler4life YJ Wrangler Technical Forum 30 10-10-2012 02:21 PM
D30/D35 pinion seal replacement raskull TJ Wrangler Technical Forum 19 08-22-2008 09:57 AM
pinion seal replacement Muddeprived TJ Wrangler Technical Forum 38 09-07-2005 04:56 PM
Pinion seal replacement boomhower YJ Wrangler Technical Forum 3 08-10-2005 08:37 AM
Pinion seal replacement Polaris TJ Wrangler Technical Forum 6 06-06-2003 12:05 AM
