Dana 44 Pinion Angle - JeepForum.com
post #1 of 4 Old 02-10-2011, 11:32 AM Thread Starter
yuma97
To complete the Dana 44 swap into my 97 TJ, I know I must adjust the pinion angle. I also know that the best way to do this is with adjustable rear control arms. To the best of my knowledge, Rubicon edition TJs don't have adjustable control arms, so how is their pinion angle changed? Are the control arm brackets welded on at a different angle? I know the transfer case and drive shaft are not the same as a 231/D35 equipped TJ, but will these changes cause the pinion angle to change? Thanks, just looking for something besides the control arm option.
yuma97 is offline
post #2 of 4 Old 02-10-2011, 11:36 AM
Gary2
The adjustable control arms are aftermarket . None of the Jeeps come with them
Gary2 is offline
post #3 of 4 Old 02-10-2011, 11:55 AM
dcope17
Only other option is to cut and move your CA brackets to get the right pinion angle... I'd get adjustable CAs before doing that.
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #4 of 4 Old 02-10-2011, 01:05 PM
biffgnar
biffgnar's Avatar
What driveshaft are you running? For a stock driveshaft, output angle of TC and pinion angle should match. This requires less adjustment of pinion and is the setup the factory goes for with stock fixed arms. If you are running a CV driveshaft then pinion angle and driveline angle need to be the same. Adjustable control arms probably the best way to do that.
Romney in 2020!
biffgnar is online now
3 inch lift Dana 35 pinion angle ? newbs TJ Wrangler Technical Forum 4 08-21-2010 07:25 AM
Dana 30 pinion to caster angle delta cj847 TJ Wrangler Technical Forum 9 09-19-2009 03:10 PM
Can't get ft pinion angle on dana 30 TJW909 TJ Wrangler Technical Forum 4 06-19-2009 05:58 PM
Front Dana 30 pinion angle Hollywoood TJ Wrangler Technical Forum 7 06-26-2007 10:03 AM
Adjusting Pinion Angle on a Dana 44 Rear Axle and After Effects dfowler TJ Wrangler Technical Forum 3 08-10-2006 04:50 AM
