Dana 44 gear oil capacity - JeepForum.com
post #1 of 26 Old 01-21-2009, 12:54 PM Thread Starter
Vegas4x4
Hi, I have a '05 Rubicon, with the lockers, Dana 44 differentials. I just changed my gear oil in the front and the fluid capacities I've seen posted says 4 pints (2 quarts), but that much won't fit in. At about a 1.3 qts it starts flowing out the fill hole. I tried driving around in circle 8's, then checked the level again but still full. Is this something I should be worried about?
Thanks,
Andy
Vegas4x4 is offline
post #2 of 26 Old 01-21-2009, 01:37 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
First Andy, a big welcome to JF. Second, you do have to buy 2 quarts but it only holds about 1.3 quarts as you already found. Make sure not to overtighten the fill plug as overtightening it can position it in too far which can jam the locker mechanism.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
post #3 of 26 Old 01-21-2009, 02:14 PM Thread Starter
Vegas4x4
Wow, quick response! Thanks!!
Well, that explains why I can't get any more oil in there then. But I'm perplexed why they would print the capacity at 2 qts, if 2 qts won't fit?? But I'm happy to find that I'm not driving it around if I did something wrong. It was my first differential lube change, so was a little concerned.
Anyway, thanks for the help!
Andy
Vegas4x4 is offline
post #4 of 26 Old 01-21-2009, 02:20 PM
TimBrown
2 quarts for a Dana 44 without a locker, it is probably generic printing for the 44
TimBrown is offline
post #5 of 26 Old 01-21-2009, 02:49 PM
NJHCx4xLIFE
Great advice that will save him from a very costly mistake.
NJHCx4xLIFE is offline
post #6 of 26 Old 01-21-2009, 04:51 PM
roadbosstx
Not to steal the thunder here, but to make sure.... Most of you guys recommend Royal Purple Synthetic 75-140 and there is no need for any additives in a Rubi D44, right? Secondly, I wasn't planning on using a gasket, just silicone, so I need to also be careful so as not to 'seat' the fill plug in too far, right? Or do you have to use a gasket on a Rubi D44 to have extra clearance?
Thanks
roadbosstx is offline
post #7 of 26 Old 01-21-2009, 05:04 PM
97casteeltj
97casteeltj's Avatar
Thanks
in the Rubi D44s it is recommended to have 75-140 synthetic (whether its royal purple or not is up to you) b/c its better for the LS and the lockers, also when i change my fluids i use some RTV, i like it better than the gaskets and i can apply it how i feel it needs, also yes don't over tighten the fill plugs on the rubi d44s b/c like Jerry already mentioned it can interfere with the locker, what i've done is wrap the plug with teflon tape and just tighten it down enough past finger tight and it holds fine and no leaks.
-John
needing a new rig....
97casteeltj is offline
post #8 of 26 Old 01-21-2009, 09:39 PM
roadbosstx
Great. Thank you 97casteeltj!
post #9 of 26 Old 12-02-2009, 11:30 AM
Mud-Hunter
Sorry to bring this back...
So I have a bag full of 80-90 in the Rubicon to change out the fluid. Should I return it for the 75-140 or am I ok?
Also went to 4 stores for the APP985s and had to get them ordered and will change out this weekend. I could swap fluid when I go to pick up the plugs if that is what is advised. Thanks and I only want the best for my baby.
Mud-Hunter is offline
post #10 of 26 Old 12-03-2009, 08:31 AM
Mud-Hunter
Hello ello ello lo oooo...
Quiet in here.
So I went back and returned the 80-90 for the 75-140 and Whoa I had no idea the difference. I got the 80-90 for $23 out the door and I bought Mobil1 75-140 for $83 out the door. Quite a shock but the guy said "think of it as a new rear end with this stuff". So does it make that much difference? I want to go home and change it out tonight but wondered if since I bought the good stuff I shouldn't go all the way and remove the covers rather than just draining and refilling? 60k miles and no clue what has been done to it? Don't have time to buy Lubelockers and don't know what RTV costs as my excursion cost me about $200 yesterday as I bought a drain pan and funnel and 7 APP985s and random things for the garage. Is it a must do or can I get away with draining and refilling IF all looks good in the old fluid i.e. no metal shavings?
Also moved what I thought was a wood burning stove that ended up being a gas stove of old into the garage last night. Just cleared it out and it now is a wood burning one. 8) It will work and we boarded up all the windows and cracks and it seemed to heat up the garage fairly well but will have to get another heater for the back of the garage to balance it out. I also need lots of lights and a good creeper! Want to do this tonight as my APP985s will be in tomorrow as no one had them in stock and had to order. THANKS!
post #11 of 26 Old 12-03-2009, 08:50 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Quiet in here...
Its quiet because you are in a thread that is 1 year old. I think everyone left.
Wheelin98TJ is offline
post #12 of 26 Old 12-03-2009, 09:04 AM
Mud-Hunter
Agreed but didn't want to make another and not sure what to do as I'm a lowly newbie but learning very quickly!
Just did a search and found this one that is the same as my rubi an 05. I learned real quick that search is my friend but also learned old threads RIP.
Thanks!
I'm also VERY scared about the over tightening thing? How do I know it is in enough but not too far? (that's what she said")
Just look at where it sits prior and try and match it upon refill?
post #13 of 26 Old 12-03-2009, 09:43 AM
-dirt-
I use black Permatex RTV, and it seems to work just fine. Give it a few bit to setup before you torque down the cover bolts and fill it though.
-dirt- is offline
post #14 of 26 Old 12-03-2009, 12:48 PM
Mud-Hunter
SO I have to pull the covers or can I just drain and fill as long as I don't see any problems in the old fluid? Not sure I can RTV by tonight and really want to get it done tonight. I couldn't drain and refill and drain and keep to use and pull the covers off next week could I?
post #15 of 26 Old 12-03-2009, 12:53 PM
-dirt-
I didn't quite catch all that drain-refill-drain stuff, but no, you don't have to pull the cover on your D44s. They have drain plugs, so you can just drain & refill.
Pulling the covers is recommended though in order to get all the shavings out and to make sure everything looks ok.
-dirt- is offline
AX5 gear oil capacity. Char250r YJ Wrangler Technical Forum 4 06-15-2009 09:22 AM
Rubicon Dana 44 capacity JLCJ7 JK Wrangler Technical Forum 1 03-17-2009 02:10 PM
Fluid Capacity for Rubi Dana 44 ISurvivedNMU TJ Wrangler Technical Forum 15 03-17-2007 08:34 AM
Dana 44 capacity ???????????? halfmoonclip TJ Wrangler Technical Forum 4 05-13-2004 01:34 PM
quick question. gear oil capacity mhmmofr0 YJ Wrangler Technical Forum 2 03-28-2004 02:03 PM
