Dana 44 Front Ford 9 inch Rear - JeepForum.com
post #1 of 3 Old 08-28-2004, 09:17 AM Thread Starter
Down&Dirty
Down&Dirty's Avatar
I am currently looking into doing this swap. I snapped the 35c again a couple days ago and now I have the opportunity to upgrade. Does anyone know of any resources that would help me make the swap? What considerations do I have to take into account? Any good places to get the adapters to fit the new axles to my driveshafts? I am totally lost when it comes to this. I have done gears before but that was in a full shop, now I am in a gravel driveway. I am planning on having the gears, and mounting points done by someone who knows what they are doing, but the rest I can do. Also, where is the best deal on the rock crawler rims, or who do I stay away from? I have to go to 5 on 5.5 instead of the 5 on 4.5 that I currently run.
53 willys wagon with less of rust and no more bugs. Now sporting a 1988 wagoneer frame, amc 360, dana 44's.
'80 CJ-5, full width, 3 link front, 1/4 elliptical rear, 38's, and propane.
Down&Dirty is offline
post #2 of 3 Old 08-30-2004, 07:41 AM
Jim Shanks
Jim Shanks's Avatar
It cost me a little bit more than usual, but I just surfed ebay and grabbed a d44 out of an '02 for $1700 or so shipped. It was a direct bolt in, and no driveshaft mods were necessary with my 2" budget boost, and 1" MML.
Jim
"Cracked Cow" '01TonTJ2a, Solid Mfg HP60's, 5.38's, ARB's, PSC full hydro, 14" coilovers, ASD roof and doors, armored everywhere sitting on 40" Iroks.
Jim Shanks is offline
post #3 of 3 Old 08-30-2004, 08:51 AM
TJSilverSport02
TJSilverSport02's Avatar
I've been looking for the stuff to do the front end:
77.5-79 F250 HP D44 has 1/2" thick tubes, and is very easy to narrow
The F250 axle, see if you can find it cheap with out the knuckles and stuff. You can then rebuild the ends with new bearings/seals/etc so everything is new.
Chevy D44 flat tops (allows for high steer) & caliper brackets
Ford rotor and hub assembly (5x5.5)
Warn Premium hubs from Napa for $95 for a pair.
Hi-steer stuff, knuckles etc HERE
drive shaft stuff
Guys at the above links have answered ?'s I've had...
For the rear I swapped in a XJ D44-also considered the 8.8 route.
TJSilverSport02 is offline
Ford 9 inch vs dana 44 stokesj19 YJ Wrangler Technical Forum 63 12-22-2016 06:56 AM
Dana 44 / Ford 9 inch Swap into YJ garr79 YJ Wrangler Technical Forum 7 06-07-2010 07:38 AM
Dana 60 vs ford 9 inch bayvilleYJ YJ Wrangler Technical Forum 30 07-10-2007 10:04 PM
What could me dana 44 front, and 9 inch rear support as far as tires? jeepcj7 TJ Wrangler Technical Forum 9 03-14-2004 05:03 PM
Where can i get a HP Dana 44 front, and a ford 9" rear, w/ same width+lug pattern? jeepcj7 TJ Wrangler Technical Forum 7 11-25-2003 02:54 PM
