Dana 44 find, yes or no? - JeepForum.com
post #1 of 36 Old 02-27-2009, 04:42 PM Thread Starter
jeepwrangler97
So I had a math exam today and told myself I deserve a reward. After class I found a junk yard. In the junkyard I found two isuzu rodeo's with dana 44's, they both(two rear axles) are clean dana 44's with disc brakes. I am pretty sure they are dana 44's. I don't know what gears they have, but it's my belief they did not have 3.73s as an option for those, maybe they did. Oh and the junk yard wants $150 for the axle with the brakes and everything. I was thinking I could change the gears to 3.73? and [B]change the axle shafts [/B]and match my current bolt pattern? any help would be appreciated, there are two there, so hopefully they won't both be gone next time I go. Should I get one, or not? Oh and I don't want any 44 vs. 8.8 debates here. Thanks guys
[IMG][/IMG]
[IMG][/IMG]
jeepwrangler97 is offline
post #2 of 36 Old 02-27-2009, 05:11 PM
never monday
it's a viable option. The gear is something weird like 4.30
never monday is offline
post #3 of 36 Old 02-27-2009, 05:21 PM Thread Starter
jeepwrangler97
Thanks, I could just swap in some 3.73's, couldn't I?
post #4 of 36 Old 02-27-2009, 05:31 PM
Imped
Imped's Avatar
Not quite that easy to re-gear the axle. You'll want a pro to do that.
OlllllllO
IndyORV
Imped is offline
post #5 of 36 Old 02-27-2009, 05:33 PM Thread Starter
jeepwrangler97
Sorry, I didn't mean me, I meant I could get it regeared to 3.73
post #6 of 36 Old 02-27-2009, 05:34 PM
Luckyduck
I just went and grabbed 2 rubi axles locked and everything for $100 each then $1000 for 2 entirely new stronger housing and bingo I got 2 locked 44's that are as strong as 1 tons for $1200
If I can get there I can wheel it!
CentralMass4wd.com
1993 Ranger 2wd - dd
1999 wranger 2.5 - it gets used for something
1978 international scout - being built
1998 Cherokee sport 4.0 auto
1957 CJ5 - restoring back to stock
Bikes:2000 Ducati Monster 900: 2001 CBR 600 F4i: 1980 CB 900
my build
Luckyduck is offline
post #7 of 36 Old 02-27-2009, 05:37 PM Thread Starter
jeepwrangler97
Where?
I could change the bolt pattern on these with new shafts, yes?
post #8 of 36 Old 02-28-2009, 04:08 PM Thread Starter
jeepwrangler97
bump.. for more input and I found out I'm aloud to keep an axle in my dorm if I need to, my RA was confused, but said I could do it.
post #9 of 36 Old 02-28-2009, 04:11 PM
Apex
Recon death squad
Apex's Avatar
Umm...Rubi axles for $100?
I want that number!
Apex is offline
post #10 of 36 Old 02-28-2009, 04:24 PM Thread Starter
jeepwrangler97
I want that number!
yeah, me too
post #11 of 36 Old 02-28-2009, 04:37 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
That is an Isuzu D44, they're geared pretty deep actually. I want to say 4.27 or 4.56. They're narrower than a TJ D44 by 2 inches.
Originally Posted by JPMagazine
'93-Up Isuzu Dana 44 Rear
The Dana 44 rear in Isuzu cute utes is 58-inches wide, has six-lug axles, and comes from the factory with disc brakes. You'll need to swap out the weird metric flange for a standard Dana 44 1310 or whatever yoke and cut and weld the spring perches to fit.
JPMagazine
Its the same amount of work as a Dana 60, Ford 9" or Ford 8.8...
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #12 of 36 Old 02-28-2009, 04:41 PM
Polecat
Polecat's Avatar
I had a buddy in college who rebuild VW Bug engines in his room.
Polecat is offline
post #13 of 36 Old 02-28-2009, 04:55 PM Thread Starter
jeepwrangler97
JPMagazine
Thanks guys, anybody using one of these
post #14 of 36 Old 02-28-2009, 05:06 PM
Unlimited04
Use the search function, you'll find lots of people use those....thats why I suggested them
Useful Write-Ups:
Funny:
post #15 of 36 Old 02-28-2009, 05:44 PM
fratis
fratis's Avatar
how exactly do you figure this?
fratis is offline
Can't find breather bolt for Dana 35 fishwater2 YJ Wrangler Technical Forum 2 10-01-2009 06:31 AM
Where can I find a pinion seal for an '04 Dana 30? BWFBezerk TJ Wrangler Technical Forum 8 09-18-2009 08:40 AM
Cant find a Dana 35 with 4.11's creepycrawly TJ Wrangler Technical Forum 21 01-22-2008 10:22 AM
Why Can't I find Dana 44 wheel U joints subzeroedj TJ Wrangler Technical Forum 6 07-29-2007 03:48 PM
Where to Find a Dana 60 Front? ONX TJ Wrangler Technical Forum 13 10-04-2006 12:34 PM
