#1 | |
Dana 44 Clunking
Since installing the new Dana 44 rear-end I have a clunking noise that feels and sounds like coming from skid plate area. I have SYE kit that I ordered from Fab Tec when I ordered the lift and was wondering if maybe the drive line is bottoming out. There are 1 1/2 inches of splines in front of the slip joint, is that enough or should the drive line be shortened. I had a dana 35 before, and the noise wasn't there prior to the swap, and yes I rechecked the torque on all the control arms, trac bar, and shocks.
#2 |
Bump back to the top
#3 |
check your bolts that hold your transfer case to the skid plate. you also may have seperated the mount that holds your tranny to the skid plate. mine was doing the same thing when i completly seperated the rubber tranny mount.
#4 | |
#5 |
i just bought the one from poly performance. they are built different b/c they are interlocked by metal in the poly bushing to limit the amount of flex so it wont separate like the stock bushing. sitting in the garage right now waiting on my lazy but to put it in.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
