-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   Dana 44 axle shaft upgrade? (http://www.jeepforum.com/forum/f9/dana-44-axle-shaft-upgrade-1080397/)
GotLime 07-31-2010 08:25 PM
I have an 04 Rubicon and I'd like to upgrade axle shafts.
To those of you that have upgraded:
Which axle shafts did you choose and why?
How much were they?
Thanks,
Chris
robncar 07-31-2010 08:41 PM
Check out Superior. We went with AlloyUSA but there have been changes in the company ownership and I'm not sure I'd recommend them now.
Heliparker 07-31-2010 08:41 PM
you cant fix something that is not broke! IMO no need to upgrade till you brake one. I went with G2 axles when I broke one. Working great so far after a year of DD and wheeling hard!
BoarderX47 07-31-2010 08:42 PM
You could upgrade to chromoly shafts but other than that there is nothing I can think of other than swapping out the axle.
Chromoly Axle Shaft Kit by Alloy USA and Other Jeep Parts and Jeep Accessories by 4 Wheel Drive Hardware-RH2
robncar 07-31-2010 08:48 PM
Originally Posted by Heliparker (Post 9884085)
you cant fix something that is not broke! IMO no need to upgrade till you brake one...
That's one philosophy but when an axle breaks, it sometimes takes something with it. Also, they have the darnedest habit of letting go in rather remote locations. Not an issue if you carry spares though.
Sundowner 07-31-2010 08:58 PM
I've heard good things about Superior, as well. I think one could upgrade to those and keep the stock shafts as spares...could they not?
Heliparker 07-31-2010 09:00 PM
I think one could upgrade to those and keep the stock shafts as spares...could they not?[/QUOTE]
very true.
mrblaine 07-31-2010 10:10 PM
very true.[/QUOTE]
True and advisable.
Sundowner 07-31-2010 11:39 PM
Originally Posted by mrblaine (Post 9884490)
True and advisable.
That's good to know. I'm also trying to figure the best way to upgrade my D44 shafts, because I'm heading towards high-clearance fenders and 35's pretty quickly: the alloy shafts would make me feel better.
I don't know much about the weak points of the axles. All I've determined thus far is that the stock air locker has a weak spot, the front outers aren't the best, and alloy shafts would be a welcome upgrade.
Too bad the D44's won't handle 37's...I'd love the extra inch of clearance.
superslayer 08-01-2010 06:35 AM
Your rear axle can handle 37's if you upgrade to a super kit. However it's your front axle which is the weakest link only the pumpkin is Dana 44 whereas the tubes/outershafts/knuckles are all Dana 30. You definitely have to truss it while also upgrading shafts.
I would also consider upgrading your brakes and steering as well.
robncar 08-01-2010 06:39 AM
Yes, as long as you keep the stock spline count (No Super Kits). :wave:
littledevilTJ 08-01-2010 06:40 AM
this is only my opinion and my experience but my buddy has ran 37 boggers on his xj 44, and it has been fine. He beat on his too, much more than I would ever. Im running 37 MTRs on my xj 44 and it has held up fine. I still am trying to find some trail spares though, just in case.
Shrek 08-01-2010 06:40 AM
I would look at RCV. When I'm ready to upgrade my Rubi axles, I'm going with RCV and eliminate the front ujoint all together.They run about $960 for the set. Lifetime warranty. None of the typical ujoint issues at full lock and under power.
robncar 08-01-2010 06:45 AM
1 Attachment(s)
Not sure about the cost delta but another option is CTM's.
superslayer 08-01-2010 07:00 AM
Why spend $500 on CTM's when you can upgrade to RCV shafts for another $400 and still have your completely assembled stock shafts to use as spares?
Besides the spicer 760x joints are PLENTY strong.
The time now is 09:03 AM.
