Dana 44 ARB problem - JeepForum.com
post #1 of 5 Old 05-12-2010, 11:08 AM Thread Starter
Hotrod97z
Hotrod97z's Avatar
Dana 44 ARB problem
I installed my ARBs. When I tested them, the D44 in the rear worked fine for about 5~10 minutes; then, the compressor came on and I heard an air leak. Upon closer inspection, I realized this air leak was coming from the rear axle tubes with the smell of differential fluid.
I checked the bulkhead connector, hoping that was the problem...ordered a new one for Rusty's. The next day, I had the bulkhead connector buttoned back you, but still had the problem. I ordered a new seal housing. I haven't had time to tear into it yet (wanted to have ALL the parts I might need in hand before I start this).
Problem 1: I receive a bulkhead connector PN 170102, which is double compression type for a 5mm plastic tube to 3/16" copper tube. The ARB came with (and parts list specifies) PN 170111, which is an O-ring type for a 5mm plastic tube to 3.5mm copper tube. The salesman at Rusty's swears it will work. Does this sound logical?
Thanks for the help.
Alan
'03 TJ
Hotrod97z is offline
post #2 of 5 Old 05-12-2010, 11:50 AM
aussied97tj
Are you sure its leaking at the bulk head fitting, because it could be leaking at the o rings inside collar
aussied97tj is offline
post #3 of 5 Old 05-12-2010, 12:29 PM
klimb2xs
x2 - When I installed my ARB I picked up an extra set of O-rings just in case they leaked.
Originally Posted by walldk View Post
Step away from from the vehicle and seek professional help.
klimb2xs is offline
post #4 of 5 Old 05-12-2010, 01:08 PM Thread Starter
Hotrod97z
Hotrod97z's Avatar
I haven't had time to open up the differential. I was hoping someone had seen something like this before and had some insight. Thanks for the help...I'll check the O-rings in the collar this weekend
Alan
'03 TJ
post #5 of 5 Old 05-12-2010, 01:25 PM
robncar
robncar's Avatar
Unfortunately, sometimes the copper tube will crack at the actuator. The only way to know is to disassemble.
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
dana 30 problem? timritchieblue TJ Wrangler Technical Forum 11 10-03-2009 07:59 PM
Dana 30 Problem Ratmeat YJ Wrangler Technical Forum 5 09-14-2009 07:29 PM
Dana 44 Rearend Problem gotriver TJ Wrangler Technical Forum 12 06-03-2009 04:20 PM
Dana 30 Problem???? bddisi TJ Wrangler Technical Forum 20 12-06-2008 09:00 AM
Problem with Dana 44s in a TJ hoggster TJ Wrangler Technical Forum 6 04-25-2008 10:44 AM
