#1 | |
Dana 44 or 35
Just bought my first jeep about two months ago and really ejoying it, Its a 2000 sahara 4.0 auto hardtop with air. still lerning about the options. What is the best way to tell if I have the dana 44 or 35
#2 |
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#3 |
#4 |
dana 35 has a rubber fill plug, dana 44 is metal
[CENTER]01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi![/CENTER] |
#5 |
When is it enough?
That is what I was going to say.
5.5" RELA NorCAl Crawlers |
#6 |
beat you too it!
#7 |
Use the search function!
I require things to do. |
#8 |
Well then Ill add that the D44s plug has a 3/8 drive hole on it
The Jeep Wave I Wave...Do You? www.militaryjeepers.com /l ,[_____], l---L -OlllllllO- ()_)-()_)--o-)_) |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
