dana 35 replacement - JeepForum.com
post #1 of 34 Old 09-02-2012, 04:12 PM Thread Starter
Redneck101
dana 35 replacement
is it possible to fit the dana 44 gears into a dana 35 axle ?
Redneck101 is offline
post #2 of 34 Old 09-02-2012, 04:14 PM
Redsand723
Nope
Redsand723 is offline
post #3 of 34 Old 09-02-2012, 04:16 PM Thread Starter
Redneck101
Is there a solution to rebuilt it stronger or I absolutely have to change the axle
post #4 of 34 Old 09-02-2012, 04:22 PM
brplatz
There is and it's called a super 35
The Second Amendment is in place in case they ignore the others.
That's like saying you wish your boyfriend was a bit less gay.
MOΛΩN ΛΑΒΕ
brplatz is offline
post #5 of 34 Old 09-02-2012, 05:29 PM
freeskier93
This is the second time I've seen this asked... where is this nonsense coming from?
freeskier93 is offline
post #6 of 34 Old 09-02-2012, 07:21 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
The question isn't nonsense, some of the responses may be... IMO
Knuckelhead is offline
post #7 of 34 Old 09-03-2012, 11:01 AM Thread Starter
Redneck101
just dont ****ing answer if you think this is non-sense : *******
post #8 of 34 Old 09-03-2012, 11:02 AM
aestrad1
Ford 8.8>Dana 44
aestrad1 is offline
post #9 of 34 Old 09-03-2012, 11:58 AM
LittleBluE
Originally Posted by aestrad1
Ford 8.8>Dana 44
Incorrect. The 8.8 offers less clearance than a D44 but the 8.8 OS easier to find. I would take a d44 with chromo shafts any day of the week over an 8.8
LittleBluE is offline
post #10 of 34 Old 09-03-2012, 12:00 PM
brplatz
Hard to say, try comparing a super88 to a dana44 with the chromos, now what do you take
MOΛΩN ΛΑΒΕ
brplatz is offline
post #11 of 34 Old 09-03-2012, 01:08 PM
LittleBluE
Still the D44, more clearance. The 8.8 does have a larger ring gear though, but they're both plenty strong. I also would take the bolt in swap over welding an 8.8 in
I would only swap a D44 of D60 under mine if I had the option and the D60 wouldn't go in for anything under 37's.
8.8 Benefits: Larger ring gear Thicker tubes 31 spline Availability Disc brakes
Disadvantages: c-clip Less ground clearance Not exactly Jeep width Not bolt in, so you better learn to weld and get good at it
D44 Benefits: Bolt in available if you have a TJ More ground clearance Larger aftermarket support
Disadvantages: Drum brakes 30 spline 8.5"? ring gear Smaller tubes More expensive if you are getting one from a TJ
post #12 of 34 Old 09-03-2012, 01:32 PM
mukluk
Originally Posted by LittleBluE View Post
Disadvantages: Drum brakes ...
If you get one from an LJ it'll have discs.
mukluk is online now
post #13 of 34 Old 09-03-2012, 02:14 PM
LittleBluE
Very true!!!
post #14 of 34 Old 09-03-2012, 03:43 PM
BamaJeepman21
I would take a 44 with chromos anyday. Then I would sleeve and truss it. Make one hell of an axle.
-Jack
BamaJeepman21 is offline
post #15 of 34 Old 09-03-2012, 05:36 PM
LittleBluE
Yep, that 44 would be a bad *** axle. I wish someone made a decent four link kit. I hear the RockKrawler kit isn't bad.
Dana 35 replacement options my91jeepyj YJ Wrangler Technical Forum 35 06-28-2012 10:39 PM
Dana 30 Replacement TJ munroejp TJ Wrangler Technical Forum 21 11-27-2009 02:21 PM
Dana 35 replacement acrijos TJ Wrangler Technical Forum 19 06-01-2009 08:57 PM
Axle replacement Dana 35 John O TJ Wrangler Technical Forum 3 09-08-2007 05:48 AM
Question about hub replacement on Dana 30 GPERSCREEPERS99 TJ Wrangler Technical Forum 6 02-24-2005 02:31 PM
