Dana 35 Problem - JeepForum.com
post #1 of 3 Old 10-09-2010, 03:07 PM Thread Starter
escape57
Dana 35 Problem
Hello,
I had a whine in the rear end that increased with acceleration. I pulled the cover off, and took it apart. I found the carrier bearing and the spider gears were bad. Also, there was play in the pin that holds the spider gears in, in the housing. Some lunch box lockers say that will not work with a limited slip differential. How do i know whether I have one or not? The rear end is a Dana 35M with 4/11 gears.
My question is- would i be better off putting a locker in/would that eliminate the need to replace the spider gears?
escape57 is offline
post #2 of 3 Old 10-09-2010, 03:13 PM
XJcruiser
Left carrier is open, right is limited slip.
XJcruiser is offline
post #3 of 3 Old 10-09-2010, 03:24 PM Thread Starter
escape57
great thank you I have open so another questionoes that play in the pin that holds the small spiders in place have any impact on a locker,does the new locker use those holes at all?
escape57 is offline
dana 35 , lockers , rear end , spider gears , whine
dana 30 problem bigred94 YJ Wrangler Technical Forum 13 07-29-2010 02:59 PM
Dana 44 ARB problem Hotrod97z TJ Wrangler Technical Forum 4 05-12-2010 02:25 PM
Dana 30 Problem Ratmeat YJ Wrangler Technical Forum 5 09-14-2009 08:29 PM
Dana 30 Problem???? bddisi TJ Wrangler Technical Forum 20 12-06-2008 10:00 AM
Problem with Dana 44s in a TJ hoggster TJ Wrangler Technical Forum 6 04-25-2008 11:44 AM
