Dana 35 locker in a Dana 30 - JeepForum.com
post #1 of 12 Old 06-27-2010, 09:57 AM Thread Starter
Farmkid
I finally got around to installing my gears in the front D30. I had an ole detroit trac-lok for a D35 sitting on the workbench. Everything fits in the D30 carrier going back together with it tuesday I will post my results then. Fits like a glove.
Farmkid is offline
post #2 of 12 Old 06-27-2010, 10:00 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
What is a Detroit trac-lok? Dana makes a Traclock for the D35c but since it is clutch based, I would not want it in my front axle if I ever drove on slick or icy roads.
Jerry Bransford is offline
post #3 of 12 Old 06-27-2010, 10:09 AM
cpleasant
cpleasant's Avatar
I have never heard of people swapping parts between two entirely different axles.
This should be an interesting read.
Originally Posted by liredneck View Post
I know your rite I seid the dealer seid the same thing as you and that I don't want them there , but I was asking another qeustin as in what do I do about the slots in the brackets couse if I just put a bolt in there it will slide back and fourth but again thank you all knowing and powerfull jeep god sorry us lesser jeep peeons might have some more qeustins in the future , so please if there to much for you sit back relax go to the next post
cpleasant is offline
post #4 of 12 Old 06-27-2010, 10:17 AM Thread Starter
Farmkid
I apoligize it's a Detroit ez-locker
Farmkid is offline
post #5 of 12 Old 06-27-2010, 12:22 PM
bandit455
i have seen this done a couple times. with good success also, the only difference between most d35 and d30 lunchboxes is the space for your c-clips on a dana 35
Eagle scout jeeper #10
The Things We Make, Make Us
bandit455 is offline
post #6 of 12 Old 01-08-2011, 01:08 PM
flh03
Farmkid, how did the d35 locker work out in the front d30? I am kicking this around. I have a Aussie in my rearend but may put it up front and get a different one for the rear.
flh03 is offline
post #7 of 12 Old 01-08-2011, 01:12 PM
joe440
Would like more info on this. Any pics of this ?
joe440 is offline
post #8 of 12 Old 01-11-2011, 08:28 AM
RowJ
Ditto......TTT
RowJ is offline
post #9 of 12 Old 01-11-2011, 12:05 PM
White99tj
Pirate has a thread going on swapping R&P from different axles. D80 to D70, HP D70 to HP D60, HP D50 to HP D44, D35 to D30, JK LP44 to LP D44.
This is some very good reading .
http://www.pirate4x4.com/forum/showthread.php?t=914583
White99tj is offline
post #10 of 12 Old 02-27-2011, 03:48 PM
lyon
Bump!
lyon is offline
post #11 of 12 Old 09-23-2011, 03:05 PM
ChrisAyers
Did this end up working?
ChrisAyers is offline
post #12 of 12 Old 09-23-2011, 03:29 PM Thread Starter
Farmkid
It worked pretty good but have decided to go with s selectable
Farmkid is offline
Dana 35 , dana 35 , locker
dana 30 locker? tbramich Wrangler General Discussion 2 05-15-2010 10:09 AM
dana 30 locker 05tjx TJ Wrangler Technical Forum 6 06-20-2006 09:46 PM
dana 30 locker phlex234 YJ Wrangler Technical Forum 13 12-19-2004 12:57 PM
Dana 35C w/ a Locker ssg11bravo30 TJ Wrangler Technical Forum 12 11-08-2003 12:42 PM
A better locker for the Dana 35? AndyMan569 YJ Wrangler Technical Forum 7 01-25-2002 09:37 AM
